Never seize???
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=65696
Author:  ibfishin [ Sun Feb 07, 2016 4:03 pm ]
Post subject:  Never seize???
Do you use on threads of bolts when installing heads, intake, exhaust, etc?
Author:  ibfishin [ Sun Feb 07, 2016 4:13 pm ]
Post subject:  Re: Never seize???
I used it when I had to replace the clutch on my GTR. Just not sure if I need to use it on everything. I had a hell of a time getting the drive disassembled so I made sure "never seize" was applied when I reinstalled everything.
Author:  flint87 [ Sun Feb 07, 2016 4:45 pm ]
Looks like you're working on all the same stuff as me right now. Can't believe how small the motor itself actually is with everything taken off.
Author:  ibfishin [ Sun Feb 07, 2016 5:56 pm ]
I'm not doing the cam yet. My case gasket isn't leaking yet.
Author:  Russ [ Sun Feb 07, 2016 5:58 pm ]
Not on the bolts. Maybe the coil screws and mounting bolts for the engine, but none of the others need it. Drive shaft, yes, so the clutch and stuff won't be stuck, flywheel nut, and prop nut threads. Everything else should pretty much come apart ok later.
Author:  ibfishin [ Sun Feb 07, 2016 9:22 pm ]
Thanks!
Author:  SCmudder7071 [ Sun Feb 07, 2016 10:03 pm ]
Never seize on the clutch. That's all you need.
Author:  deadbird8 [ Mon Feb 08, 2016 6:23 am ]
Author:  Russ [ Mon Feb 08, 2016 9:34 am ]
Good idea. I always figured the studs were supposed to come off at the same time. ;) jk, but have noticed that before.
Author:  deadbird8 [ Tue Feb 09, 2016 5:17 am ]
