It is currently Mon Feb 02, 2026 9:10 am
[ 5 posts ] |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
 Compression question
Anyone ever have a stage 2 GTR with 165 psi on both cylinders? motor was built by SETX performance, and was at 162 before I got the crank and flywheel balanced, and put new rings and at 165 again(where it was when I bought the motor used with 85hrs on it). just curious, will push my 1750 dfou special right at 30-32 with a unworn gt 2 blade 10p. still doing right at 28 - 28.4 with 4 men and hunting crap.
just curious on opinions.
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
| Tue Apr 26, 2016 6:02 am |
Will C
 Re: Compression question
I had an setx motor recently in shop with same compression as u have. I believe your heads were already shaved when you got it.
| Tue Apr 26, 2016 7:28 am |
tyler_johnson
Yes supposedly around forty thousandths, but can get no confirmation on that. And I was just checking to see if that was anywhere near normal when you hear number constantly over 200.
| Tue Apr 26, 2016 7:32 am |
Will C
Thats right on for 40thou. The 200 guys usally have piston rod combos
| Tue Apr 26, 2016 7:48 am |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
Sound about spot on
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
| Tue Apr 26, 2016 8:35 am |
[ 5 posts ] |
