| Cam timing curiosity http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=66620 |
| Author: | Pigglet [ Tue Apr 19, 2016 6:11 pm ] |
| Post subject: | Cam timing curiosity |
Has anyone tried to advance or retard there camshafts for performance gains? There's 70 teeth on the cam so it could go a little over 5 degrees either way.... |
| Author: | tyler_johnson [ Tue Apr 19, 2016 7:16 pm ] |
| Post subject: | Re: Cam timing curiosity |
might be a new discovery! Sent from my SM-G900V using Tapatalk |
| Author: | flint87 [ Tue Apr 19, 2016 7:42 pm ] |
On a stock cam? What a pain in the ass that would be when you could buy a performance cam with more lift and duration plus advanced timing. It's not that hard to swap the cam but not worth jacking around with a stock cam while you have it apart plus the case gasket is $30 I think. Sent from my iPhone using Tapatalk |
| Author: | banded-mallard [ Wed Apr 20, 2016 4:54 am ] |
| Author: | Will [ Wed Apr 20, 2016 5:44 am ] |
Too far, one tooth is 10.28 degrees and not worth messing with the stock cam, better off with a proven grind. You can advance the ignition timing easier and gain a little by either using advance timing keys on the flywheel or removing the key and using a timing light and lock it down. If it is a CDI, it will help on the bottom some but not much until the advance in the coils kick in around 2200rpm. |
| Author: | Pigglet [ Wed Apr 20, 2016 6:23 am ] |
10 4 I was just curious if it could or had been done. Over 10 degrees would probly have some valve to piston clearance issues |
| Author: | deadbird8 [ Tue Apr 26, 2016 6:06 am ] |
People have re-broached the timing gear on the crank for different advance settings. I believe this is how the original cam timing advance cams were developed. |
