It is currently Mon Feb 02, 2026 7:48 am
Reply to topic  [ 5 posts ]
 Compression question
Post Compression question
Anyone ever have a stage 2 GTR with 165 psi on both cylinders? motor was built by SETX performance, and was at 162 before I got the crank and flywheel balanced, and put new rings and at 165 again(where it was when I bought the motor used with 85hrs on it). just curious, will push my 1750 dfou special right at 30-32 with a unworn gt 2 blade 10p. still doing right at 28 - 28.4 with 4 men and hunting crap.
just curious on opinions.
Tue Apr 26, 2016 6:02 am
Post Re: Compression question
I had an setx motor recently in shop with same compression as u have. I believe your heads were already shaved when you got it.
Tue Apr 26, 2016 7:28 am
Yes supposedly around forty thousandths, but can get no confirmation on that. And I was just checking to see if that was anywhere near normal when you hear number constantly over 200.
Tue Apr 26, 2016 7:32 am
Thats right on for 40thou. The 200 guys usally have piston rod combos
Tue Apr 26, 2016 7:48 am
Sound about spot on
Tue Apr 26, 2016 8:35 am
