It is currently Mon Feb 02, 2026 9:26 am
Reply to topic  [ 12 posts ]
 Gasket removal question
Post Gasket removal question
What is the most efficient way to remove the factory head gasket form the block?
35 GTR pushing an 18' Alumitech Custom
Thu Feb 04, 2016 10:28 am
Post Re: Gasket removal question
Razor blade scraper works well
Thu Feb 04, 2016 11:28 am
That is what I figured. Didn't know if there was any kind of release agent on the market you guys were using in conjunction with a plastic scraper.
Thu Feb 04, 2016 12:03 pm
After I scrape, I use acetone on a rag to clean any residue.
Thu Feb 04, 2016 12:49 pm
90 die grinder with 3m pad
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Thu Feb 04, 2016 1:54 pm
sharp razor for the thick stuff, a scotch brite pad works good for the little shit. Schmitt got it^^
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Feb 04, 2016 2:03 pm
:lol: I like to a papertowel in the pushrod galleys to catch the small stuff. Then vacuum out after scraping. Makes for a nice cleanup. Skip on the grinder :lol:
Thu Feb 04, 2016 2:16 pm
I put paper towels in the galleys, razor scraped, scotch brite, and acetoned.
Thu Feb 04, 2016 2:26 pm
I go get the girl that works the local corner, run a lil of dat crotch rot on the case. Let it set, wipe away and your good to go. No need for tools
Thu Feb 04, 2016 4:52 pm
That might work as well.... did not think about the blue waffle ooze.
Thu Feb 04, 2016 6:48 pm
Permatex gasket remover. oven cleaner and a plastic scraper or a plastic credit card edge to scrape with. I have never seen a engine builder yet that used a die grinder and rollex discs. There is a ra finish that needs to be maintained on a aluminum head surface. Also disc dust can migrate in to places it shouldn't be in.
JUST ANOTHER FARMER ON WELFARE
Thu Feb 04, 2016 9:57 pm
New Member
Loctite makes a paint striper/gasket remover it works well.
Tue Apr 26, 2016 1:01 pm
