It is currently Mon Feb 02, 2026 6:03 am
[ 7 posts ] |
Pigglet
Joined: Thu Jun 11, 2015 12:57 pm Posts: 58 Location: Illinois
 Cam timing curiosity
Has anyone tried to advance or retard there camshafts for performance gains? There's 70 teeth on the cam so it could go a little over 5 degrees either way....
_________________ 1960 uncle j gtr35
| Tue Apr 19, 2016 6:11 pm |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
 Re: Cam timing curiosity
might be a new discovery!
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
| Tue Apr 19, 2016 7:16 pm |
flint87
On a stock cam? What a pain in the ass that would be when you could buy a performance cam with more lift and duration plus advanced timing. It's not that hard to swap the cam but not worth jacking around with a stock cam while you have it apart plus the case gasket is $30 I think.
| Tue Apr 19, 2016 7:42 pm |
banded-mallard
| Wed Apr 20, 2016 4:54 am |
Will
Too far, one tooth is 10.28 degrees and not worth messing with the stock cam, better off with a proven grind. You can advance the ignition timing easier and gain a little by either using advance timing keys on the flywheel or removing the key and using a timing light and lock it down. If it is a CDI, it will help on the bottom some but not much until the advance in the coils kick in around 2200rpm.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Apr 20, 2016 5:44 am |
Pigglet
10 4 I was just curious if it could or had been done. Over 10 degrees would probly have some valve to piston clearance issues
| Wed Apr 20, 2016 6:23 am |
deadbird8
People have re-broached the timing gear on the crank for different advance settings. I believe this is how the original cam timing advance cams were developed.
| Tue Apr 26, 2016 6:06 am |
[ 7 posts ] |
