NLW352
 Hoisting engine
GTR 37, i need to remove it from my transom. I do not see any lift points on the motor. There are 2, what appear to be lift points, near the valve covers. i assume this would be just for lifting the motor, not the frame and drive. I know someone has experience with this, advice would be appreciated.
Thanks in advance
Wed Aug 17, 2016 7:33 am |
MaXXis85
 Re: Hoisting engine
You can use those points to lift the entire frame.
Wed Aug 17, 2016 7:40 am |
FL_waterfowler
Joined: Tue May 24, 2016 2:14 pm Posts: 108 Location: Pensacola, FL
 Re: Hoisting engine
I used the points you speak of to lift it off and and put it on a stand with no issues, but not sure how well they would hold up of you are looking at leaving it hanging from those points. Just my .02
Sent using smoke signals
_________________ 15/42 Alweld 25 MBLT
wade_660
 Re: Hoisting engine
Agreed. Much stronger than they look
Wed Aug 17, 2016 10:09 am |
flint87
 Re: Hoisting engine
Mine bent when the engine was lifted off with them. I go through the frame below the motor now when taking my gdsd off. A regular engine stand works great for storing it when it's off too
Wed Aug 17, 2016 12:52 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Hoisting engine
Yeah they'll bend a Lil to the inside the first time, but leave em bent and use em.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Wed Aug 17, 2016 5:18 pm |
brycecheramie
 Re: Hoisting engine
I hung my prodrive from those same eyes, for a week. The are a lot stronger than they look.
Wed Aug 17, 2016 7:00 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Hoisting engine
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Wed Aug 17, 2016 7:46 pm |
flint87
 Re: Hoisting engine
Wed Aug 17, 2016 8:33 pm |
SETx Longtail
 Re: Hoisting engine
That's how GD totes them around and how I was told to pick it up I ever had to. I've taken mine off the transom a few different times and always used them. I made up a lifting cable with two small shackles and a ring in the center. It picks the whole unit straight up off the transom, they hold it no problem. That's why they're there. I was told by several people NOT to use the brackets on the heads. Those are for the powerhead only. Those bolts are small, thread into already crap aluminum heads. They weren't meant to hold the weight of a frame too. I have known folks to pull them out of the head and have to helicoil the holes.
Wed Aug 17, 2016 8:48 pm |
NLW352
 Re: Hoisting engine
Emailed Gatortail to get to the root, not sure why i didn't do that to begin with, confirmed the liftpoints on the head will support the entire unit.
Thu Aug 18, 2016 2:32 pm |
