Hydraulic trim on PD
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6901
Author:  Short On Cache [ Mon Jan 04, 2010 3:08 pm ]
Post subject:  Hydraulic trim on PD
what are your opinions on using hydraulic trim or manual? Kinda considering swapping to the Hydraulic. Are there any problems I should know about?
Author:  POKER1 [ Mon Jan 04, 2010 4:14 pm ]
Post subject:  Re: Hydraulic trim on PD
You talkin about the wheel. Phuck Dat, just about covers it. Or you could just ask Mudhole.... :lol:
Author:  JIMMY W [ Mon Jan 04, 2010 6:12 pm ]
The Hydro is the way to go!!
Author:  Short On Cache [ Mon Jan 04, 2010 6:22 pm ]
Poker 1 Are you saying that they had problems with the hydro trim or what?
Author:  POKER1 [ Mon Jan 04, 2010 6:25 pm ]
No, the hydro is the only way to go. That wheel will give you a heart attack.
Author:  Short On Cache [ Mon Jan 04, 2010 6:57 pm ]
Im thinking I am going that way soon
Author:  SP [ Mon Jan 04, 2010 7:15 pm ]
Never driven the non hydro, but I can tell you the hydro trim is not as precise as i would imagine the wheel is. When you are trimming down, the motor slides another inch or two after you let off the button. You get used to it, but at times it can be annoying when running wide open and trying to get the trim exactly right. If somebody has a fix for this, would love to hear it, but I am just assuming they are all like that. As far as convenience goes...a no brainer.
Author:  dead animal [ Mon Jan 04, 2010 9:12 pm ]
i'm still running the winch trim. i think i prefer the winch setup best.
if anyone out there is running the winch, be sure to throw away that stainless cable and go get sum 5/16'' synthetic rope and use that stuff. cheaper and last 10x longer.
i've got over 400hrs on my synthetic rope and it stll looks new. i was changing out the stainless wirerope every couple months.
Author:  Full Throttle [ Tue Jan 05, 2010 7:57 am ]
Author:  Mudhole [ Tue Jan 05, 2010 8:48 am ]
Poker is talkin bout me, being one of the last "wheel" guys to switch over to the hyd. let me just say this, while you never have to worry bout the wheel, they hyd. trim is wwwwaaaaayyyyy better! ;)
Author:  dead animal [ Wed Jan 06, 2010 7:46 pm ]
Where do I find the synthetic stuff?[/quote]
i got mine from a hardware store, any 4x4 place that sells winches should carry it.
Author:  GoldenHunter20 [ Wed Aug 01, 2012 5:31 am ]
I'm looking to get my first mud motor and trying to keep cost down so it will likely be a used 27 HP. I've never ran a mud motor. Almost all of the areas I run are rivers with hard bottoms, hardly any mud, just shallow. How much trim adjustment will I actually be doing, I understand there will always be some, but tyring to determine if I should stay with the manual trim to keep cost down. Thanks.
Author:  med [ Wed Aug 01, 2012 5:48 am ]
If you aren't running mud I think you needing to move the trim would be minimal. I have the wheel. Thought I'd hate it but for what I run its fine for now. Unless your having to really dig or have drastic changes in boat load you can pretty much set it and forget it. I wouldn't sweat buying one with a wheel. You can always upgrade. And go with a 36 if you can swing it. You won't regret it. A 27 will just piss you off.
Tapatalk 2
Author:  POKER1 [ Fri Aug 03, 2012 9:50 pm ]
Trim is used way more than just in mud. I rarely run mud but am constantly on the trim. Once you figure out just how beneficial it is in all situations you will kick yourself for not having it. Just running clear water with a load I use my trim alot. Trim down as you get on the gas and trim up as your getting on top helps step a load much faster for me. Yiu may need to trim just because your load shift some. Get the trim and you will thank yourself now. Save awhile longer and get a 36 w/HT.
Author:  mud slinger 69 [ Sat Aug 04, 2012 8:11 am ]
I just got power trim on my motor.Dont know how i ran it before.Get it
Author:  mizzippi jb [ Sat Aug 11, 2012 3:19 pm ]
Just put the power trim unit on the pd. it's amazing how much more it will get down in the mud versus the wheel. Even goes up a lot further.
Author:  CJB [ Sat Aug 11, 2012 4:08 pm ]
My motor lasted all of 2 trips with the wheel before I got hydro.
