estadalis
Cranking battery issue
Guys I have a battery that was new in march. I've had to use my spare 3 times. I think the motor is draining it somehow. I have my nav lights, bildge, and led's I hardly ever turn on hooked up to the same battery. I have an on and off switch for the battery and I turn it off when I'm not running. But for some reason I'll get a trip, maybe two before the battery dies. I don't think it's a bad battery bc it started to drain my spare, and I can't figure out why. Thanks for any input
Mon Jun 05, 2017 5:43 am |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
Re: Cranking battery issue
You could install a master switch by the battery. That would be the easiest, otherwise you'll have to start trouble shooting.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Mon Jun 05, 2017 5:49 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Got a Volt meter? if so check voltage on battery, then start motor idle up to around 2000 rpms, voltage should be at least 13.5 vdc (at least higher than before starting). If you have a disconnect switch, with switch off, measure battery voltage, turn on switch(all accessories off) measure voltage. If nothing is "powering up or pulling on batterie, voltage should be almost the same. If you see a voltage drop something is draining on battery.
I gonna say either the battery is bad or your motor is not charging the battery.
BTW way what motor ?
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Mon Jun 05, 2017 7:50 am |
estadalis
I have a master switch. Which is why I'm confused.
I have a 2010 prodrive
Mon Jun 05, 2017 8:45 am |
4Cody4
Have you tested your master switch?
Mon Jun 05, 2017 8:50 am |
estadalis
No I haven't. How would I go about it?
Mon Jun 05, 2017 10:52 am |
4Cody4
Use a bolt meter as stated before. Turn your master switch off and see if it's drawing power.
Mon Jun 05, 2017 11:45 am |
BlueShamu
Unplug your clutch wires from the harness at the motor. Give it a few days and go back and check the battery......just speaking from experience.....right before the clutch wouldn't disengage.
Mon Jun 05, 2017 7:19 pm |
