It is currently Mon Apr 15, 2024 11:09 pm
Reply to topic  [ 7 posts ]
 Mid range bog
Post Mid range bog
Got 35 briggs with mikuni,Also has all internals done too. Has bog from about 2500 to 4000 rpms. After 4000 rpms seems to run somewhat ok. What could cause this?
Sat Aug 05, 2017 9:53 pm
Post Re: Mid range bog
Was this one running good one day then went south or is it an issue since it was built? Could be a tuning issue , fueling issue, gasket failure, valves, etc
Sat Aug 05, 2017 11:46 pm
Just started getting worst. Had cracked block, so while I tore it down, had valve job done on it to try fix problem. But didn't help. Also cleaned carb but didn't notice anything there either.
Sun Aug 06, 2017 7:07 am
Sounds like a tuning issue or possible cam timing issue. A wideband o2 sensor with a bung welded in the pipe will be a good place to start. Degreeing the cam would find a cam problem if it has one. Any chance your needle is set too high and fat?
Sun Aug 06, 2017 11:29 am
Haven't changed anything on carb since first put together, just recently started acting up. Heard to put clip down a notch and try that on needle?
Sun Aug 06, 2017 12:03 pm
If you are lean in the mid then yes moving clip down 1 will fatten it up
Sun Aug 06, 2017 2:01 pm
I agree with wills first suggestion. I'd drop the needle (move the clip higher 1 notch). If it was backfiring mid throttle, I'd say raise the needle. It's bogging, though, which sounds like too much fuel.
#TheGhostBoat
Sun Aug 06, 2017 4:29 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 93 guests
