It is currently Wed Apr 24, 2024 12:10 am
[ 4 posts ] |
23 mud buddy problems need help
Fuquabw2016
I'm trying to fix a buddy's 23 mud buddy it cranks and runs fine but soon as you trim it up or down it dies ? Like it does when you pull kill switch . Could it be broke wire grounding it out ? Anyone else had this problem ?
Fri Aug 18, 2017 5:45 pm |
Darryle
Joined: Sun Mar 22, 2009 3:44 pm Posts: 250 Location: Fort Worth, Texas
Re: 23 mud buddy problems need help
Does sound like a short of some kind.
_________________ 2017 Atchafalaya Outdoor Designs 1244 2017 Copperhead 12hp
Fri Aug 18, 2017 6:34 pm |
Fuquabw2016
Figured it out someone that had it before him had one the trim wires hooked up to the wrong spot
Fri Aug 18, 2017 8:22 pm |
Fuquabw2016
This 23 hp vanguard engine someone installed a after market carb on it guy that I got it from said tach said it would rev up to like 7000 Rpms figured that's way to high .
Question is what is it supposed to run and when they installed it think they removed governor where they supposed to do that and do I need to get a aftermarket rev limiter for it still has stock one ? Also when it was on the guys mud buddy frame it crank and ran fine outa the water but bogged way down when put prop in water ? Pretty sure both head gaskets around blow could that be the motors problem causing it to bog down ?
Mon Aug 28, 2017 9:03 pm |
[ 4 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 196 guests |
