RoyBoy10
Joined: Wed Jan 26, 2011 1:28 pm Posts: 515 Location: setx
Mikuni help needed
Here lately I've been having gas steadily flow out the overflow on my mikuni while the motor is running. I was told that more than likely the tab on the float needs to be bent some? I'm a complete rookie at knowing which way and how much to bend it. I have no problem taking it apart and doing what needs to be down but need to know where to start. Any input on what to do or other possible solutions would be greatly appreciated.
_________________ 1754GT 35GTR
Tue Sep 05, 2017 6:24 pm |
jc
Re: Mikuni help needed
Here is a link to the manual. It should be page 8 that explains how to set the float height.
Tue Sep 05, 2017 6:52 pm |
Russ
Pm sent
MaXXis85
Float misadjusted, Wrong needle/seat, or bad needle seat o ring.
Wed Sep 06, 2017 5:21 am |
cledet
Joined: Mon Feb 13, 2012 9:23 am Posts: 35 Location: Metry, LA
Make sure you have the correct needle valve for mudmotor application. The Mikuni "standard" size needle valve is too big and will overflow the bowl - ask me how I know
_________________ 18' x 54" Uncle J Custom w/ PD 36 FPR and Calen's Stage 2
Wed Sep 06, 2017 5:28 pm |
Russ
The float needle is worn. He's getting a new one. 4 years old.
Wed Sep 06, 2017 6:02 pm |
RoyBoy10
Wed Sep 06, 2017 7:37 pm |
MaXXis85
Russ is the best! Russ is the best!
Thu Sep 07, 2017 5:38 am |
Russ
I'm punching you in your cooter.
Thu Sep 07, 2017 6:40 am |
MaXXis85
Thu Sep 07, 2017 12:17 pm |
luckyhat12
Joined: Thu Dec 08, 2011 5:50 pm Posts: 30 Location: DFW
Is the 2.3 needle and seat the correct version for a mud motor?
I am getting constant overflow now too but the closest shop to work on it is 2 hours away so I usually end up ordering parts and working on stuff myself.
_________________ 2054 WC Custom CC pushed by a GTR
Mon Dec 04, 2017 12:11 pm |
Russ
yes.
Mon Dec 04, 2017 1:17 pm |
