200plus
Joined: Mon Feb 20, 2017 5:21 pm Posts: 24 Location: Middle Tenn.
Governor spring for gatore tail
I am in need of a purple governor spring and also governor idle spring also for 35 hp GT.
_________________ ALL THANGSWILD TAXIDERMY
Wed Sep 13, 2017 7:06 pm |
Will C
Re: Governor spring for gatore tail
Ive got a brown4300 if u can use it.The purples have to come off pre cdi carb motors i think
Wed Sep 13, 2017 8:16 pm |
Will C
And most stock carb motors dont need or use the goverend idle spring . A couple have them but you can set idle with the carb idle screw
Wed Sep 13, 2017 8:22 pm |
cb5331
The governed idle is nice. Keeps the motor from bogging and stalling under load.
Wed Sep 13, 2017 8:49 pm |
brycecheramie
Wed Sep 13, 2017 9:15 pm |
Will C
I agree on that part. I put a new carb motor on a mans gatortail last week and it didnt have one from the factory. But i see yalls point
Wed Sep 13, 2017 10:12 pm |
BlueShamu
Thu Sep 14, 2017 2:08 am |
MaXXis85
Thu Sep 14, 2017 5:58 am |
bluesky2012
Thu Sep 14, 2017 8:01 am |
BlueShamu
Thu Sep 14, 2017 11:27 am |
200plus
My motor is a stage 2 but it has the stock carb without the governor idle spring. I plan on up grading the carb also. I just have finished the boat about 2 weeks ago . Just in time to take some teal and wood ducks this past weekend. Thanks for the help.
Thu Sep 14, 2017 5:08 pm |
bluesky2012
Do yourself the favor and spend $2 and put the idle spring on till then.
Thu Sep 14, 2017 5:17 pm |
BlueShamu
I'm telling you, mine runs better than it ever has without the governor, spring and all the linkage. Idle is adjusted with the idle screw. Thing purrs at low idle. Gets straight to WOT.
Thu Sep 14, 2017 7:49 pm |
200plus
Blueshamu maybe I will try that. I can always put it back if it don't work for me.
Thu Sep 14, 2017 8:41 pm |
MaXXis85
Most people knock the stock carb, But having it tuned well (which is a tadbit harder) will not hinder a lot of performance.
Fri Sep 15, 2017 6:02 am |
bluesky2012
Fri Sep 15, 2017 8:12 am |
