It is currently Fri Mar 29, 2024 12:04 am
[ 6 posts ] |
Governor Shaft and gear Removal
Fowl Rooster
My crank case is open for a seal replacement. While I'm in there should I remove the Governor shaft and Gear? What would be the benifits of this? Motor is a 2013 MB 4500 BD. Thanks for any input. I did a search and nothing much came up.
Wed Sep 20, 2017 6:44 pm |
Russ
Re: Governor Shaft and gear Removal
4500bd have a stock carb?
Wed Sep 20, 2017 6:57 pm |
Fowl Rooster
No. Mikuni
Wed Sep 20, 2017 8:08 pm |
Russ
then yes, you can remove the gear and other innards, and cut the shaft below the keeper ring, or pull it and thread that hole where the shaft goes through the top of the block and put a bolt in it.
Wed Sep 20, 2017 9:12 pm |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
I always do this when making mods or whenever I have to crack open a case. Advantage is, no non used parts inside the crankcase to possibly come loose or break and cause catastrophic failure. Good idea imo.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Thu Sep 21, 2017 4:49 am |
Ricerunner
Joined: Fri Sep 11, 2015 6:56 pm Posts: 887 Location: Summerville, SC
Like smoke and Russ said take it out!!!!!!! I've seen the results of the gov gear letting go inside a built engine and it isn't good. Nothing is salvageable. It should just slide off the shaft might have to use a small pry bar. I cut the flattened part off the bottom of the shaft, two snap rings hold the shaft in, one inside and one out. I found it's easier to take it out the through the crankcase but you'll have to rotate the engine over to gain clearance and watch those gears they can be sharp.
Fri Sep 22, 2017 6:42 am |
[ 6 posts ] |
Users browsing this forum: No registered users and 212 guests |
