It is currently Fri Apr 19, 2024 3:25 am
[ 7 posts ] |
Prodrive EFI E2 intake backfire
steinb3rg
Experiencing backfire inside the intake. Anyone had this happen before. Motor is 2013 36hp with the Prodrive EFI E2 kit.
_________________ 17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true." "Where'd you hear that?" "The internet"
Sun Oct 15, 2017 9:55 am |
lilfukr79
Re: Prodrive EFI E2 intake backfire
Valve seats seating properly?
Sun Oct 15, 2017 2:56 pm |
brycecheramie
Valve lash set correctly?
Sun Oct 15, 2017 4:59 pm |
Will C
As they said and while your checking the valves make sure you have full travel of rockers,,'meaning the cam isn't flat
Sun Oct 15, 2017 7:14 pm |
steinb3rg
Is a compression test the only way to check if the valves are seating properly? Anyone in the Gonzales/Prairieville area have the tools to do it?
I checked the valve lash using instructions on the BPS website, all set at 0.005. By rotating the flywheel all rockers appear to moving like they are supposed to.
Could intake gaskets be a cause? Is there a good way to check this?
Mon Oct 16, 2017 5:57 am |
Will C
Yes an intake gasket can do it. Remove cowling and inspect around where the intake bolts to heads for a missing piece of gasket. A leakdown tester is used to check for valve seal
Mon Oct 16, 2017 8:02 am |
MaXXis85
Intake gasket leak or intake VALVE leak. Typically the culprit of a lean pop/cough out the intake
Thu Oct 19, 2017 9:16 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 336 guests |
