It is currently Sun Jun 09, 2024 11:22 am
Reply to topic  [ 12 posts ]
 37 EFI GTR- Falling out of gear
Post 37 EFI GTR- Falling out of gear
I have been having an issue recently where the motor will slip out of forward into neutral while running or when hitting a log. Has anyone else had this issue and is the fix just to change the F-N-R switch assuming it is bad? I have a new switch headed my way but wondered if there was something else I should look into.
Mon Nov 06, 2017 9:56 am
Post Re: 37 EFI GTR- Falling out of gear
Mon Nov 06, 2017 8:10 pm
yes, falls out of forward into neutral
Tue Nov 07, 2017 11:18 am
Tue Nov 07, 2017 8:32 pm
Lots do this. Supposedly there is another switch available that doesn't do that.. I've yet to really look into it unfortunately
1850 Uncle J
Delta Performance level 4 GTR
Tue Nov 07, 2017 9:33 pm
$9k-$10k for a motor and you cant even get a good $5 toggle switch? :lol:
Tue Nov 07, 2017 10:53 pm
Wed Nov 08, 2017 6:14 am
Wed Nov 08, 2017 6:47 am
The Shallco rocker switches for trims are $50 bucks baw.. even from GT.
Wed Nov 08, 2017 10:54 am
Wed Nov 08, 2017 10:31 pm
A toggle cannot handle the load. If you use a toggle you need to wire in two relays to reverse polarity to get the motor to work in bot directions. Hence the single less complicated switch.
Thu Nov 09, 2017 11:40 am
Fri Nov 10, 2017 3:06 pm
Users browsing this forum: Google [Bot] and 188 guests
