It is currently Fri Apr 19, 2024 8:35 am
Reply to topic  [ 2 posts ]
 Mud buddy powerhead swap
Post Mud buddy powerhead swap
I have a 2012 27 hp kohler engine on a 2012 mud buddy hd sport frame. I am wondering if i am able to upgrade just the powerhead and it bolt straight onto my frame without modifications or having to purchase other parts. Specifically I am looking to put a vanguard 35 in place of my kohler 27. What modifications if any will be needed to make this work. Thanks for the help
Mon Nov 06, 2017 1:32 pm
Post Re: Mud buddy powerhead swap
I would check dimensions of the Kohler against the Briggs, like the output shaft height from frame base to OP shaft center, and OP shafts diameter and length. Also Kohlers hole spacing at its base to MB frame. and belt housing holes where it bolts to Crank cover. Briggs maybe different. Probably check clutch bearing for inside diameter and gear tooth count. Might be able to look up some of these dimensions before removing motor. Save having some unexpected surprises.
Mon Nov 06, 2017 5:26 pm
Users browsing this forum: Majestic-12 [Bot] and 335 guests
