It is currently Sat Jun 15, 2024 4:30 pm
Reply to topic  [ 14 posts ]
 Is my motor stock
Post Is my motor stock
I have a 2015 gator tail 35 in the water it doesn't bounce the rev limiter till about 4700 rpm is that factory or is there something done to the engine I bought the engine used and never thought to ask
Tue Nov 28, 2017 7:07 pm
Post Re: Is my motor stock
Sounds like you have 4750 rev limit coils on the motor.
Are you running those rpm’s consistently? Or just when the prop comes out the water?
Refurbishing a Prodrive
Tue Nov 28, 2017 7:12 pm
You are turning 4700 rpms in the water? If so, then no I doubt it is stock. The stock CDI coils do limit rpms at 4700 rpms OOW but I highly doubt you're running those RPMs in the water with a stock motor unless your prop is worn like crap. What speeds are you seeing and do you have it trimmed right?
Tue Nov 28, 2017 7:13 pm
The prop is in the water at 4700 rpm but trimmed a little high I run best trimmed down at about 4400 to 4500 rpm that's where I run consistently it goes about 24 to 26 mph
Wed Nov 29, 2017 9:13 am
Sounds like you’ve got the lower pitched prop with a stock motor.
I could be wrong though.
Wed Nov 29, 2017 9:26 am
Or wasted prop
Wed Nov 29, 2017 11:39 am
Wed Nov 29, 2017 11:56 am
That is alot of RPM's to be going nowhere very fast.
Wed Nov 29, 2017 12:24 pm
Should I try a new prop what should I get
Wed Nov 29, 2017 1:31 pm
Try a big blade
Wed Nov 29, 2017 3:12 pm
Has anyone ran the hammer prop or is it to much prop
Wed Nov 29, 2017 10:25 pm
Prob too much
Wed Nov 29, 2017 10:55 pm
Hammers are NOT for stock motors.
Your prop is worn more than likely.
Thu Nov 30, 2017 6:05 am
For a 35 that does sound high. However i do run my best speeds around 4600-4700 rpm on a stock 37.
Sun Dec 03, 2017 6:56 pm
Users browsing this forum: No registered users and 173 guests
