It is currently Sun Jul 13, 2025 4:12 am
Reply to topic  [ 11 posts ]
 new 42 mm mikuni floods before turning motor over
Post new 42 mm mikuni floods before turning motor over
I decided to upgrade to the 42mm mikuni kit from bps and the rapid r exhaust on my 35 gtr before the season starts, 2013 model gtr. No matter how I trim the motor the carb floods immediately when I pump the fuel bulb. I swapped the needle and seat to the smaller one included in the kit as recommended in bps instructions. I have done many carb rebuilds and replacements on outboards and and small engines, but also realize that no matter how many I have done things can still be overlooked. float high is set at closed off level float, no adjustment was needed. I cannot think of any other reason than a bad needle and seat that a new carb would flood like that.
Any suggestions would be greatly appreciated.
thanks
Sun Sep 17, 2017 11:47 am
Post Re: new 42 mm mikuni floods before turning motor over
Hook a pressure gauge on your fuel line and see how much pressure the bulb will actually create. More than likely it is higher than the needle and seat can handle.
Sun Sep 17, 2017 1:18 pm
Pull the bowl and watch what's happening when you play with the float. Its got to be something easy staring at you
Sun Sep 17, 2017 1:50 pm
Make sure it's the 2.3 needle and seat.
Sun Sep 17, 2017 9:34 pm
A primer bulb creates more pressure than needed for the mikuni. I can get gas to flow out my overflow tube as well if I pump the bulb to much. These carbs have an internal accelerator pump and I never have to pump the primer bulb to get it to start. I crank it over and if it doesn't start within a couple revs, I squeeze the throttle lever twice and she fires right up regardless if its 90 deg. or -15 deg. I think you're blowing gas right by the needle and seat.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Sep 18, 2017 9:35 am
if you pump the bulb until its HARD, it will overflow the Mikuni.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Mon Sep 18, 2017 10:41 am
I have also tried gravity feeding fuel to the carb no fuel pump and no primer bulb it floods as well, I can pull the bowl and flip hold the float up to close the needle and if I blow on the hose it will leak through the needle and seat until the fuel is gone. Once the fuel is gone it seals the air and doesnt leak any longer. this thing is driving me crazy, Needle and seat have been changed to the smaller one included in the bps kit, sent bps pics and they agree that I installed the correct needle and seat.
Wed Sep 20, 2017 10:23 pm
Any chance of an imperfection in the oring that goes around the seat. Or a scratch or something
Wed Sep 20, 2017 10:54 pm
It doesn't take much of an imperfection to allow gas to leak past the needle and seat. Double check everything to make sure there is no damage. Check movement of float as well.
1854 Prodigy Open
HDR/Stage 3 mods
Thu Sep 21, 2017 4:47 am
Bayou Surface Drive
337-351-0362
Thu Sep 21, 2017 8:20 am
got the flooding fixed it was a bad needle or seat I could tap it and get it to seal just didn't want to sit right consistently so I replaced and no more flooding.
Wed Dec 20, 2017 11:55 pm
Users browsing this forum: Majestic-12 [Bot] and 75 guests
