Manually roll the motor over
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=71787
Author:  dsw1000 [ Mon Dec 25, 2017 10:09 am ]
Post subject:  Manually roll the motor over
Ok this may get me beat up but how do you manually turn the motor over to set the valve lash? I found all the posts for setting the lash but everybody just says roll the motor over. I set the motor in fwd gear and turn the prop but the valves never move. What am i missing?
Author:  Will C [ Mon Dec 25, 2017 10:15 am ]
Post subject:  Re: Manually roll the motor over
Turn key on to engage clutch? Remove spark plugs also
Author:  ibfishinb [ Mon Dec 25, 2017 7:46 pm ]
What will said.
Author:  dsw1000 [ Mon Dec 25, 2017 7:51 pm ]
Author:  CypressCritter [ Tue Dec 26, 2017 9:49 am ]
LMAO!!!! Its the simpler things in life that are entertaining and sometimes it is the solution!
BTW According to chemistry, alcohol is a solution!!!
OH! and don't forget to turn the key off when you get finished, so you don't run down your battery like I did!!!
Author:  Smoke [ Tue Dec 26, 2017 11:26 am ]
Author:  Russ [ Tue Dec 26, 2017 7:25 pm ]
