It is currently Wed Sep 24, 2025 4:43 am
Reply to topic  [ 14 posts ]
 Gatortail popping/missing under load
Post Gatortail popping/missing under load
Wondering if anyone has ran into the same problem im having. I have a 2009 gatortail non cdi gatortail that i just got back from delta performance a couple weeks ago, i had a new block new mikuni carb new cam new coils new vodoo exhuast and heads done. Ran good first 2 trips and today it started popping and sputtering mostly at half to full throttle on acceleration. Seems to run ok after held wide open. Delta closed this week so just trying to check a few things. https://youtu.be/cNt7GFXVuBg
1754 southfork with hopkins prop on moded gtr
Thu Dec 28, 2017 4:37 pm
Post Re: Gatortail popping/missing under load
You're not bouncing off rev limiter, are you?
Thu Dec 28, 2017 5:07 pm
Check the wiring on the limiter. Good clean power and ground to limiter box. No rubbed wire on low oil pres sensor. Or just unplug limiter for 1 test. Also check carb to boot seal, Ive seen a few get loose and go lean. Lower intake leak, valves settled now and too tight... adjust check? Fouled sparkplug, sparkplug cap arcing on heat shield. Random guesses
Thu Dec 28, 2017 5:29 pm
Piece of trash in main jet..
Thu Dec 28, 2017 5:30 pm
No they forgot to install the rev limiter still in the box. My rpm at 3900 in the water at wot. Heavy boat
Thu Dec 28, 2017 5:32 pm
I checked carb to boot, taped up spark plug boots too make sure no arcing, intake is tight.
Thu Dec 28, 2017 5:36 pm
That does eliminate the limiter... check spark plugs for lean condition. Are you comfortable checking the valves adjustments?
Thu Dec 28, 2017 5:40 pm
Also what about disconnecting the kill/ safety switch just as a check. Could have water in switch or..
Thu Dec 28, 2017 5:49 pm
Ill try the valves tomorrow ive done them before just not since delta worked on it, only got like 2 hours on it but i guess still woth checking. I changed plugs, if anything its a little rich i smell gas on the plugs
Thu Dec 28, 2017 5:58 pm
I hate problems like this cause it runs fine on the trailer, hard yo check stuff while running
Thu Dec 28, 2017 6:01 pm
With only 2 hrs I doubt valves are an issue. Try the kill wire disconnect. Hope u find something easy
Thu Dec 28, 2017 6:02 pm
With only 2 hours, I would definitely check valve adjustments. If they weren't torqued to spec and sometimes even when they are, those jam nuts can loosen up. Also, the rocker bolts can back out. Not common, but happens even when torqued. Will listed everything to check, and don't assume it's all good because it was just worked on. Something small is causing that issue, and tight intake bolts don't mean the intake gaskets are fine. Under load, that's definitely a potential culprit, as is the carb having trash in it somewhere, spark, etc.
#TheGhostBoat
Thu Dec 28, 2017 10:52 pm
Thu Dec 28, 2017 11:02 pm
Mine was doing that recently. Intake was loose.
I tightened the intake and still had an issue. I then replaced the intake gasket and changed the plugs, checked valves (They were fine). Problem went away.
Sat Dec 30, 2017 9:54 am
