It is currently Fri Apr 19, 2024 2:35 pm
[ 7 posts ] |
Need help with a clutch issue on a GTR
Evan2121
This past Saturday I snapped the belt on my GTR (manual reverse). Being the smart one I am I thought you had to remove the clutch and the lower unit to replace the belt (stupid I know). So I got the belt on and everything put back together. When I crank the motor the prop begins to spin as it would if it were in gear at idol speed. So my question is, what have I done wrong to cause the motor to act like it’s in gear when it isn’t? The clutch still engages but it is useless because the belt is already turning at a speed that would would when normally in gear.
Any help is greatly appriciated
Wed Jan 17, 2018 8:57 pm |
MaXXis85
Re: Need help with a clutch issue on a GTR
Is the belt tension good? Typically a spinning prop is thick oil (cold oil) in planetary and not enough grease in the LU
Thu Jan 18, 2018 8:44 am |
Evan2121
Yes, the belt tension is good. And it is spinning a lot faster than that. You can’t stop the spin with a 2x4 like you could when it’s just free spinning.
Thu Jan 18, 2018 9:03 am |
MaXXis85
check to see if the armature disc is rubbing the rotor.
Thu Jan 18, 2018 9:42 am |
Evan2121
What is the armature disc?
Thu Jan 18, 2018 11:19 am |
3rd Coast Killer
Joined: Thu Aug 27, 2009 3:17 pm Posts: 2624 Location: League City, Texas. It's where I play.
Correct Clutch installed?
Short vs Long.... I had the incorrect sent to me once....
Kool-Aid Brigade
www.southernfowler.com
Thu Jan 18, 2018 11:40 am |
MaXXis85
ALSO.... did you put the little spacer between the crank and the clutch magnet?
Thu Jan 18, 2018 1:12 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 396 guests |
