It is currently Thu Mar 28, 2024 7:03 am
[ 3 posts ] |
prodrive1999
Piston Rings
If your Piston rings are worn and causing blowby, would you need to replace the entire block or can you replace just the rings?
Tue Feb 27, 2018 2:13 pm |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
Re: Piston Rings
You should be able hone the cylinder and install new rings.
If the cylinder has wear you can bore it out and go to the next size up piston. (Shouldn't need a new block)
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Tue Feb 27, 2018 2:18 pm |
MaXXis85
Re: Piston Rings
Hone, bore check, GAP rings.
Wed Feb 28, 2018 9:28 am |
[ 3 posts ] |
Users browsing this forum: Google [Bot] and 197 guests |
