It is currently Fri Apr 19, 2024 9:37 am
[ 8 posts ] |
Pd 37 higher idle and sputtering
woodie_slayer
My pd 37 was acting weird when my idle earlier was around 850-900rpms then after cranking up 2hrs later it randomly increased to 1060-1080rpms and wouldn't decrease.Then after that,i put it in gear and it sputtered the whole time with the throttle wide open .So i turned it off for 5 mins and it went away.Has anyone had this happen or have a clue whats going on?
Mon Mar 05, 2018 12:19 am |
Will C
Re: Pd 37 higher idle and sputtering
Check engine light blinking at you?
Mon Mar 05, 2018 9:10 am |
woodie_slayer
Its not the updated efi
Mon Mar 05, 2018 9:17 am |
Will C
It would be nice if a shop in your area can check the ecu for codes. Aside from that clean and tighten ground and power wires at engine and at battery
Mon Mar 05, 2018 9:56 am |
woodie_slayer
Ok will do.does it sound like a surge somewhere to you Will? This thing had me dumbfounded yesterday,thankfully the fish were biting 400yds off haha.
Mon Mar 05, 2018 10:07 am |
MaXXis85
Also I have seen mis adjusted TPS sensors, but it sounds like a simple connection issue.
Mon Mar 05, 2018 11:04 am |
woodie_slayer
Alright fellas I found out what it was the hard way.it was the ground to the battery and it burned the crap out of me.thank y'all for helping out,I appreciate it.
Wed Mar 07, 2018 7:01 pm |
Will C
Easy fix,,, good deal
Thu Mar 08, 2018 1:31 am |
[ 8 posts ] |
Users browsing this forum: muddiejeep and 340 guests |
