It is currently Tue Jun 24, 2025 8:55 am
Reply to topic  [ 5 posts ]
 Briggs piston pin fit?
Post Briggs piston pin fit?
Quick question, but are the pins pressed or floating in the rod end?
Been awhile since I tore one down and cannot recall.
Sun Jun 03, 2018 10:17 am
Post Re: Briggs piston pin fit?
It's a pretty snug fit, but doesn't need a press.
#TheGhostBoat
Sun Jun 03, 2018 10:19 am
in all honest it is too FUCKING tight lol. Most all motors I take apart the bottom of the piston is discolored at the piston pin from lack of clearance... It is splash lubed..
Mon Jun 04, 2018 1:51 pm
Mon Jun 04, 2018 5:51 pm
yep. inconsistency. They should free float in both the piston and the rod.. I usually see more of the piston being too light and it rotates on the rod only. A lot of times I see it on motors than some joe bubba has take apart and has beaten the piston pin with a punch "mushrooming" the ends causing issues too... so. There isn't enough clearance IMO to start with stock though.
Wed Jun 06, 2018 5:19 am
Users browsing this forum: Majestic-12 [Bot] and 107 guests
