Idle rpm http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=72674 |
Author: | jz_meinert [ Tue Jul 10, 2018 1:37 pm ] |
Post subject: | Idle rpm |
What's the ideal rpm at idle? Mine is hanging around the mid 800's. Should it be a little higher than that? Sent from my iPhone using Tapatalk |
Author: | Russ [ Tue Jul 10, 2018 1:48 pm ] |
Post subject: | Re: Idle rpm |
Splash lubrication. I suggest neutral idle around 1250, which (depending on carb) should put in-gear idle around 950-1000. No, it might not sound as cool as a slower idle, but I'd like everything get the oil it needs rather than take any chance it won't. I can trim the prop up to slow my speed in water. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | brycecheramie [ Tue Jul 10, 2018 2:05 pm ] |
Author: | jz_meinert [ Tue Jul 10, 2018 2:24 pm ] |
Yea its a 40 hdr. Just seems low to me Sent from my iPhone using Tapatalk |
Author: | jz_meinert [ Tue Jul 10, 2018 2:25 pm ] |
Mid 800's neutral idle. Didn't mention that Sent from my iPhone using Tapatalk |
Author: | Russ [ Tue Jul 10, 2018 2:46 pm ] |
Efi or not, the lubrication didn't change, did it? That only changes the effect putting it in gear will have. My opinion doesn't matter much, but the man asked lol #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
Author: | Will C [ Tue Jul 10, 2018 3:49 pm ] |
Y'all are both correct, lol |
Author: | MaXXis85 [ Wed Jul 11, 2018 7:33 am ] |
I can make an EFI idle at whatever RPM I want, Its more than just opening the throttle screw. There is a method to setting the TPS to tell the ECM its at "idle". 1250 is about spot on no load for good lube of the cylinders and camshaft. |
