It is currently Tue Jun 04, 2024 4:15 am
[ 8 posts ] |
jz_meinert
Joined: Sat Jun 09, 2018 9:36 am Posts: 42 Location: Texas
Idle rpm
What's the ideal rpm at idle? Mine is hanging around the mid 800's. Should it be a little higher than that?
1854 Prodigy Elite-Mud Buddy 40 hdr
Tue Jul 10, 2018 1:37 pm |
Russ
Re: Idle rpm
Splash lubrication. I suggest neutral idle around 1250, which (depending on carb) should put in-gear idle around 950-1000. No, it might not sound as cool as a slower idle, but I'd like everything get the oil it needs rather than take any chance it won't. I can trim the prop up to slow my speed in water.
Tue Jul 10, 2018 1:48 pm |
brycecheramie
Re: Idle rpm
Tue Jul 10, 2018 2:05 pm |
jz_meinert
Re: Idle rpm
Yea its a 40 hdr. Just seems low to me
Tue Jul 10, 2018 2:24 pm |
jz_meinert
Re: Idle rpm
Mid 800's neutral idle. Didn't mention that
Tue Jul 10, 2018 2:25 pm |
Russ
Re: Idle rpm
Efi or not, the lubrication didn't change, did it? That only changes the effect putting it in gear will have. My opinion doesn't matter much, but the man asked lol
Tue Jul 10, 2018 2:46 pm |
Will C
Re: Idle rpm
Y'all are both correct, lol
Tue Jul 10, 2018 3:49 pm |
MaXXis85
Re: Idle rpm
I can make an EFI idle at whatever RPM I want, Its more than just opening the throttle screw. There is a method to setting the TPS to tell the ECM its at "idle". 1250 is about spot on no load for good lube of the cylinders and camshaft.
Wed Jul 11, 2018 7:33 am |
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 164 guests |
