calvin
Joined: Sun Aug 14, 2016 6:08 pm Posts: 63 Location: SOUTHERN ILLINOIS
vangard 35 missing
I have a 35 vangaurd with delta level 3. Last Friday night setting bank poles everything was fine. Saturday morning cheching them motor did not want to idle and run fine down the water. Sunday changed plugs, all fuel line, took carb off and cleaned, and this morning retuned carb on trailer not in the water. Put in water today and when up to operating temp it did not want to idle or at low rpm with load missed and then wot you could here a miss here and there. Any suggestions or help with this issue would be greatly appriciated. Oh and valves were adjusted in the last ten hours.
Thanks in advance, The guy with a motor issue
_________________ GATORTRAX 1754, HUNT DECK, GTR35 STAGE 3
Sat Jul 21, 2018 7:43 pm |
GNSPEED
Re: vangard 35 missing
efi or carb
Sun Jul 22, 2018 11:05 am |
Will C
I think he is a carb motor if it says 35. Possible intake gasket leak. Check the valve adjustments just so you're not overlooking something easy. Weird batch of fuel. Somewhere to start anyway
Sun Jul 22, 2018 11:35 am |
Will C
Sun Jul 22, 2018 11:37 am |
ibfishinb
When mine did that it was a loose intake. I went ahead and replaced the gasket, torqued everything back down, and all was good.
Sun Jul 22, 2018 5:33 pm |
calvin
Think I found the problem. Pulled front cover and plug wire is wore and can start to see the wire. But have been all over the internet and cant find my part numbers. Where do you guys get parts from on the internet
Sun Jul 22, 2018 7:08 pm |
bluesky2012
Partstree.com
Sun Jul 22, 2018 7:27 pm |
Russ
Use partstree for part numbers, then shop where youd like. They take a while to ship sometimes, and on some parts can be a good bit more expensive.
Sun Jul 22, 2018 7:45 pm |
MaXXis85
You have to buy a whole coil. The wire isn't serviceable.
Mon Jul 23, 2018 5:05 am |
GNSPEED
Will I did have a nice 86 but sold to pay off shop,it wasn't to fast mid to low 12s at 108 depending on weather.
Mon Jul 23, 2018 10:02 pm |
