| Striped out a bolt... http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=73081 |
| Author: | boatguy [ Sun Oct 07, 2018 7:37 pm ] |
| Post subject: | Striped out a bolt... |
OK, the motor is a 4400 HDR 2yrs old. I over torqued one of the 4 bolts that hold the valve cover on. Should I just get the next size bigger bolt or put a Helicoil in it... never have done this before.. Any advice would be appreciated... Thanks |
| Author: | GNSPEED [ Sun Oct 07, 2018 7:52 pm ] |
| Post subject: | Re: Striped out a bolt... |
longer bolt should catch enough to hold or nut on bottom of longer bolt |
| Author: | Russ [ Sun Oct 07, 2018 8:44 pm ] |
Helicoil works too, but the longer bolt with a nut is the best idea. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | boatguy [ Mon Oct 08, 2018 4:02 am ] |
| Author: | Russ [ Mon Oct 08, 2018 5:36 am ] |
Once that heat shield is out of the way, the lower 2 are easy to reach. Same with the upper 2, just a different heat shield. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | prodrivinggatortail [ Mon Oct 08, 2018 9:54 am ] |
Why not install a stud in the head and you won't have this problem again? Should probably come from the factory with studs in the heads but they don't so that should be one of the first corrections made at first valve setting. |
| Author: | boatguy [ Tue Oct 09, 2018 6:41 pm ] |
| Author: | MaXXis85 [ Wed Oct 10, 2018 5:01 am ] |
Helicoil is the best way. The heck with pulling a heat shield for a valve adjust. |
| Author: | prodrivinggatortail [ Wed Oct 10, 2018 8:13 am ] |
| Author: | OwenDickeson [ Wed Oct 10, 2018 8:29 am ] |
Helicoil it real quick and be done with it. Don't be scurred. |
| Author: | MaXXis85 [ Wed Oct 10, 2018 2:36 pm ] |
| Author: | prodrivinggatortail [ Fri Oct 12, 2018 11:32 am ] |
| Author: | boatguy [ Fri Oct 12, 2018 4:42 pm ] |
| Author: | MaXXis85 [ Mon Oct 15, 2018 12:33 pm ] |
| Author: | boatguy [ Mon Oct 15, 2018 2:54 pm ] |
| Author: | MaXXis85 [ Tue Oct 16, 2018 5:33 am ] |
This is MMT. That Guy is always trying to bust someones balls, Hes probably a good feller overall. He does bump his chest every once in a while on here. |
| Author: | prodrivinggatortail [ Tue Oct 16, 2018 8:53 am ] |
| Author: | prodrivinggatortail [ Tue Oct 16, 2018 8:55 am ] |
