It is currently Tue Oct 20, 2026 6:10 am
Reply to topic  [ 11 posts ]
 Vanguard 35 HD carburetor part question
Post Vanguard 35 HD carburetor part question
So I went to clean out my carburetor for the first time. 2010 vanguard 35 HD Sport. Trying to get the bowl screws off I gripped the body too hard and this little part broke off.
Looks like some micro adjust dial but I can’t tell the function. It has one for both sides.
The break didn’t take it out of the carburetor, just made it to where there is no ability to control the adjustment I assume it makes.
Can anyone tell me what it does and if it makes a difference in our motors?
TIA
2010 Mudbuddy 35 HD Sport on a 2010 excel 1754
Mods: BPS original crossover exhaust (that's it)
Wed Jan 30, 2019 7:06 pm
Post Re: Vanguard 35 HD carburetor part question
That is your Air / Fuel idle screw.
You would really need to get it fixed so you don't have any idle issues.
Thu Jan 31, 2019 12:59 pm
Thank you for the response. That was my first post. I apologize for the lazy question. In the time between I wrote it and it being approved I actually found the information about it on this forum. I’ve been reading a ton of old posts to soak up some knowledge on these engines as I want to begin getting better performance out of mine and I’d like to do it myself as much as possible. Breaking off the afr idle needle knob on my first carb cleaning was not a good start.
Thu Jan 31, 2019 5:15 pm
Thu Jan 31, 2019 5:17 pm
Pull the heads, ship in a USPS flat rate box. Cost you 14 bucks to ship.
#TheGhostBoat
Thu Jan 31, 2019 5:47 pm
Your leakdown will probably show decent leakage from the intake valve seat. If needed you can send me the top end including carb, heads, intake etc. I will set it up and send it back. Let us know what u find with leakdown
Thu Jan 31, 2019 10:37 pm
The stinking leak down test kit I ordered on amazon arrived today but it’s defective junk. I’ll have to order another kit from a different MFG and get those numbers next week.
I could see a bunch of black deposit on the cylinder head when I peered down in there. I have no doubt I might be losing pressure but I’d like to know the severity.
Will C I will probably take you up on your offer once I get good baseline numbers of the engine.
Fri Feb 01, 2019 4:26 pm
I'm in the same boat as you Houghtonic, my adjustment screws broke also and had I replaced the one cylinder head this far(leaking intake) and now it's time to fix the other. Should I buy another new Oem cylinder or just send them both in to somebody to get re-worked??? Then look into getting a Mikuni vs repairing the stock carb?
Sun Feb 03, 2019 3:02 pm
Mon Feb 04, 2019 1:52 pm
Mon Feb 04, 2019 5:27 pm
Will ought to be along shortly to provide his contact info.
#TheGhostBoat
Mon Feb 04, 2019 5:55 pm
