It is currently Fri Apr 19, 2024 8:19 am
[ 8 posts ] |
Johnyd883
09 Prodrive issues
I have an 09 36hp pro drive that I just replaced the clutch, sump gasket , and flywheel fan on after it shattered because the clutch gave out on me, I went to crank it the other day and it’s turning over but not firing, the spark plugs have sparks, I tried cranking it without the deodes, and I can smell gas but it still won’t fire at all, any guesses to the problem? Thanks in advance
Wed May 22, 2019 6:33 pm |
banded-mallard
Re: 09 Prodrive issues
Thu May 23, 2019 3:27 am |
Russ
If he's getting spark, it's not the kill switch. He also mentioned unplugging the diodes, which removes the kill switch from the circuit.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
Thu May 23, 2019 6:46 am |
Johnyd883
What could be past the plugs? I know its getting gas to it, could it be anything to do with the cam?
Thu May 23, 2019 9:12 am |
Will
Replaced the sump gasket as in you had the block apart? If so, did you mess with the cam and get it out of timing? Same thing with fan shroud, did you mess with the flywheel and get it out of timing?
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Thu May 23, 2019 11:02 am |
Johnyd883
Yes the more I think about it the cam is probably out of line, any tips on getting this to line up? are their pre set line up marks on the cam? would this make it not fire?
Thu May 23, 2019 2:08 pm |
Will
If it is out of timing, you will have to take it back apart, yes there are divet marks that must line up, yes it will not fire if not timed properly.
Thu May 23, 2019 3:44 pm |
cb5331
If it's too far out of timing, you could have smashed up your valves too.
Thu May 23, 2019 7:49 pm |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 294 guests |
