It is currently Fri Apr 19, 2024 3:15 am
[ 7 posts ] |
Jaeger09
Running on one cylinder
I am currently running on one cylinder on a vanguard 36. Occasionally the engine will run on both cylinders. I have run through the gambit of troubleshooting to include
1- set and confirmed valves adjusted properly
2- getting spark at both plugs. When I pull the plug wire on cylinder the engine is running on, and leave the non running cylinder plugged in to the spark plug that cylinder will run.
3- no intake or exhaust leaks
4- fuel clean and new fuel filter
5- carb cleaned
Not sure where else to go with it. Any suggestions?
Mon Nov 04, 2019 6:06 pm |
Russ
Re: Running on one cylinder
Leakdown test. Wrap the plug boots all the way back to the cowling, or even the coil, with electrical tape in case you're leaking spark.
#CFFITR #GhostBoat #Whoneedsphysicsihaveamudmotor
Mon Nov 04, 2019 6:34 pm |
Russ
Now, on the trailer, typically cylinder 2 won't do much. Only under load does it start to work. My engine doesnt sound much, if any, different with cylinder 2 spark plug boot unhooked. Different story in the water in gear.
Mon Nov 04, 2019 6:37 pm |
Jaeger09
Mon Nov 04, 2019 6:56 pm |
Russ
Nope. Never put a gun on it.
Mon Nov 04, 2019 9:45 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
I just had the same problem. After much trial and error, I found that one of my spark plugs had a hairline crack in it. New plugs fixed it. Now I've also had a diode go bad, which will cause it to run on one cylinder.
Mon Nov 04, 2019 10:43 pm |
mranderson27
I’m battling a similar issue myself. I’ve been through the mikuni (thoroughly), checked and rechecked last (Willy fast YouTube method), when I get home From thanksgiving now I’ll pull my coweling and run electrical tape. If that doesn’t do it I will be at a a complete loss. My next move will be to lap my valves or have a valve job done.
Thu Nov 28, 2019 2:00 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 315 guests |
