Riverman24
Gtr 37 xd oil leak
Have a 2018 gtr 37xd and hunted last sunday when i got home and looked over the motor as usual noticed the motor is leaking a little bit of oil on the backside at the top looks like the gasket sealer may have went bad or isnt sealing.... so im not real sure about how to pull the planet housing and clutch off to remover that cover to re seal it...
Tue Nov 05, 2019 7:11 pm |
Koondog62
Re: Gtr 37 xd oil leak
Should it not be covered under warranty?
Wed Nov 06, 2019 4:46 am |
Riverman24
Wed Nov 06, 2019 6:05 am |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
Common issue. It’s caused by vibration. One of the bolts loosened up on you.
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Wed Nov 06, 2019 9:10 pm |
Riverman24
Thu Nov 07, 2019 2:26 pm |
brycecheramie
Thu Nov 07, 2019 3:42 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Thu Nov 07, 2019 5:06 pm |
Riverman24
Wed Nov 13, 2019 3:02 pm |
Will
Wed Nov 13, 2019 3:14 pm |
brycecheramie
Wed Nov 13, 2019 3:20 pm |
Will C
I got a customer with new 40’s on a dual rig. Both engines seep in that same spot. Its the up and down vibration of cylinder 2. Over the years everybody has learned their own tricks to solve it.
Wed Nov 13, 2019 3:24 pm |
Riverman24
Wed Nov 13, 2019 7:01 pm |
Riverman24
Yamabonded it back together with red locktite on all case bolts.[/quote]
Makes sense ill tear it down after season but doesnt leak enough for me to do it now.. only leaks if i make long runs wide open
Wed Nov 13, 2019 7:10 pm |
Riverman24
You lucky you got 50 hrs out of it before it started leaking![/quote]I have over 100 on my new 40 Prodrive and nothing leaks. [/quote] Lmao pretty sure those prodrives come with come briggs motors too musta got lucky my brothers pd has 55 hrs and the motor leaks hmmm[/quote] Guess you never heard of a Kawasaki on the PD. hmmmmm[/quote] Well he said "new" pd 40 i didnt know those came with kawi motors
Wed Nov 13, 2019 7:14 pm |
Will
Prodrive does not come new with Kawasaki. That's aftermarket retrofit.
Wed Nov 13, 2019 9:21 pm |
brycecheramie
I wish prodrive would put the Kawasaki's new out the shop.
I loved my Pro-Kawi.
I really debating between a new 40hp PD or a used PD and put another kawi on it.
Thu Nov 14, 2019 6:14 am |
Will
Thu Nov 14, 2019 7:18 am |
MaXXis85
It is under warranty. You can have it repaired for free. They always leak at #2 cylinder at the second bolt above the top oil port and down to the bolt below the bottom oil port. anywhere in that area will be the oil leak.
Thu Nov 14, 2019 7:33 am |
