| Gaskets http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=8382 |
| Author: | fowl habbit [ Fri Mar 12, 2010 4:24 pm ] |
| Post subject: | Gaskets |
Is their anywhere else I can get new gaskets for my 35 besides through Mud Buddy. I need 2 upper head Gaskets 2 intake gaskets 2 intake cover gaskets. Im getting my heads back from the shop in town tuesday or wednesday so I would like to get them ASAP |
| Author: | bayouboy [ Fri Mar 12, 2010 4:33 pm ] |
| Post subject: | Re: Gaskets |
Jacks small engines. not sure on the part #'s. Someone on here might have em. You'll need the engine model # off the side your block by the oil filter. it should be 6 digits and start with 613... and the type (example 0110-E1) http://www.jackssmallengines.com/help.cfm |
| Author: | fowl habbit [ Fri Mar 12, 2010 4:51 pm ] |
Ok Ill try that thanks |
| Author: | Pooh Bear [ Fri Mar 12, 2010 9:56 pm ] |
only order 1 valve gasket set,it comes with 2 of everything. I made the mistake and ordered 2 sets for Benelliman,so we now have 4 of everything. The set only cost $31.68 a peice from Jacks.Your model number should be 613477-0121-e1. Your valve gasket set part number is 841123 .Hope this helps. |
| Author: | Sonny13 [ Sat Mar 13, 2010 12:18 am ] |
Any small engine shop that works on Briggs motors should be able to get the m next day for you. |
| Author: | bjg [ Sat Mar 13, 2010 12:26 am ] |
Get a entire gasket kit from briggs. It even has valve seals in it. |
| Author: | bayouboy [ Sat Mar 13, 2010 7:04 am ] |
This site is a good source of ref. #'s to part #'s http://bsintek.basco.com/BriggsDocument ... rvFVJ1DajI Gecker carries the nicer Flatout gaskets. http://www.mudboatmotor.com/html/flatout_gaskets.html |
