36v MinnKota RipTide, 60” Shaft 101 Thrust
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=32&t=75327
Author:  BlueShamu [ Tue Sep 29, 2020 5:08 pm ]
Post subject:  36v MinnKota RipTide, 60” Shaft 101 Thrust
Got this trolling motor with a boat we just bought. We already had a GPS trolling motor for the boat. So, this one is up for sale. This trolling motor shows very little wear. Previous owner said he rarely used it and it shows. The prop looks brand new. It is a 36 volt, variable control with forward and reverse. It has a 60 inch shaft. It will come with the quick release mounting bracket to take it on and off the boat, quickly. It also has a telescoping “Top Notch Trolling” handle. Also will come with the 3 prong MinnKota plug. Previous owner had this trolling motor set up using the big foot deck switches. Probably worked ideally with the Top Notch handle. I can plug it into the receptacle on the boat to show you how quiet the motor sounds and to show that it works as it should.
First $550 takes it home. Face to face in the Prairieville/Dutchtown area.
Sent from the ISS using Tapatalk.
