It is currently Tue Jul 15, 2025 12:08 am
Reply to topic  [ 11 posts ]
 Frog Spit
Post Frog Spit
does frog spit work as well when its rolled on, as it would when its sprayed on?
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Thu May 06, 2010 6:34 am
Post Re: Frog Spit
You need dat extra MPH bad huh? :D
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu May 06, 2010 7:29 am
Post Re: Frog Spit
i dont see why i would matter...just do it!
16X60GD 27HP Surface Drive
Thu May 06, 2010 10:22 am
Profile YIM WWW
Post Re: Frog Spit
Dig up some of the old threads. Should be fine. I think they said start in the back and work towards the front. And roll it on horizontal, not the length of the boat. That way if it starts to chip off, it won't rip off the whole length of the boat in one big sheet.
Also you may look into a product called coat-it. Made by goop. One of the boys on here just did his boat, and my lil bro ordered some for his. Seems to be a very similar product, not quite as slick, but still pretty damn slick. Also about half the price, designed for the same thing.
Thu May 06, 2010 1:09 pm
Post Re: Frog Spit
It depends on were you running at.. if you are running the Lower Mississippi, Port Fourch., or Venise, you do not need anything on your bottom.. The floating oil will help you glide accross any surviving vegetation.
Thu May 06, 2010 1:31 pm
Post Re: Frog Spit
Thu May 06, 2010 4:50 pm
Post Re: Frog Spit
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Thu May 06, 2010 4:59 pm
Post Re: Frog Spit
Thu May 06, 2010 9:20 pm
Post Re: Frog Spit
Thu May 06, 2010 9:21 pm
Post Re: Frog Spit
36hp pro-drive pushin a 1748 rick aucoin skiff
1500hp Mitsubishi pushing a 50' push boat
200merc pushing a 20' Mako
Thu May 06, 2010 9:28 pm
Post Re: Frog Spit
Fri May 07, 2010 5:58 am
Users browsing this forum: No registered users and 98 guests
