godvl
Joined: Fri Feb 06, 2009 8:36 am Posts: 253 Location: Nac-o-no where, tx
 easier way?
has anyone found an easier way to remove hydro turf? im bout to give up.
Mon Jun 28, 2010 9:44 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
 Re: easier way?
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Mon Jun 28, 2010 9:46 pm |
godvl
 Re: easier way?
Never tried to remove it, but I have some bad arse chisles/scrapers if you wanna try them. May could try and use a hair drier to heat up and possibly melt some of the adhesive. Why are u removing it Josh?[/quote]
i may take you up on those scrapers. im finally getting around to patching the cracks that i have, and im sure the foam is water logged like a sob. seems like im gettin more and more water commin in.
Mon Jun 28, 2010 9:54 pm |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
 Re: easier way?
try a hair dryer. heat up the glue then one of those large industrial scrapers from home depot / lowes. there like 30 bucks.
Mon Jun 28, 2010 9:57 pm |
marsh bandit
Joined: Wed Jan 14, 2009 12:02 pm Posts: 584 Location: Pearland, Texas
 Re: easier way?
Try using steam maybe? I no they use it to take off alot if other stuff. Also 3m has a product to use to get rid of excess adhesive, might work.
_________________ Sold my boat so now im ridin in a cozy pick-up truck to the blind to shoot ducks and a 60' Hatteras to catch fish on
Mon Jun 28, 2010 10:00 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: easier way?
Is the glue rubbery or hard? I use a huge sharp filet knife to remove laminate from fukked up countertops when I have to, but the glue is kinda rubbery, just peel the corners up and run the knife under it as you peel upwards.
_________________ Put yer face in the myrtles.
Mon Jun 28, 2010 10:03 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Re: easier way?
Gas
Mon Jun 28, 2010 10:05 pm |
godvl
 Re: easier way?
Mon Jun 28, 2010 10:08 pm |
DeathMetalDukk
 Re: easier way?
Yeah just filet it off then, a thin sharp blade will work, just like skin on a catfish
Mon Jun 28, 2010 10:11 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: easier way?
I replaced a piece of mine on the bow. Best thing I found was a metal paint a scrapper or putty knife with about a 2' wide blade. Sharpen it up and then in a chisel motion cut the bulk off. All that was left was the glue so I then used my grinder with a multi flap sanding disk to knock that off.
_________________ 18x48 Charles Leonard / 36PD
Mon Jun 28, 2010 10:15 pm |
jus10inla
 Re: easier way?
like i said.. Hair Dryer.. it will heat up the glue to melt it then scrape it off. that is the method we use to take stickers off of box trucks n trailers!
Mon Jun 28, 2010 10:25 pm |
godvl
 Re: easier way?
finally got all the hydro turf off this morn. i used a heat gun and it was still a pain. i ended up finding 3 cracks, all were located behind the bench at the first weld on three different braces, they went clear through to the bottom. but i should be up and runnin by fri. as for the foam, there was none in the floor, i thought they all came with it to begin with
again thanks for the tips
Tue Jun 29, 2010 7:57 pm |
marsh bandit
 Re: easier way?
I think they had foam in the floor, and then did without it, and then went back to it. I know my 07' didn't have it but my 09' does
Wed Jun 30, 2010 7:58 am |
