It is currently Sun Feb 15, 2026 4:54 am
Reply to topic  [ 8 posts ]
 Wiring it up...
Post Wiring it up...
Need to run some wire from bow to stern of my pd boat - would like to run inside one of the longitudal ribs. Whats the easiest way?
18_48 X-Series 36 PD
Sun Jul 11, 2010 6:05 pm
Post Re: Wiring it up...
Get you a fish tape. Feed the fish tape thru the rib, attach wire to the fish tape, and pull it back thru. It can be done with one person, but a second set of hands definately helps.
Sun Jul 11, 2010 6:11 pm
another way that is a little easier, get some 3/4 in conduit. protects the wires but it is still very accessable if you need to add any later or rewire. You can run the conduit right next to the rib under the cross braces. Just an Idea. If not your gonna need the fish tape.
Sun Jul 11, 2010 6:33 pm
Thanks - Going to give the fish tape a try!
Sun Jul 11, 2010 7:30 pm
X2 on the fish tape. See my link in my signature. I had to wire my KC lights from the front to back along the side. Fish tape was my only savior.
Mon Jul 12, 2010 10:46 pm
If you run conduit, put some pieces of weedeater string in there. One or two. Leave them a little long. That way if you add on stuff later you can just tape the new wire and pull it right through. Saw this on a new bay boat and thought it was brilliant.
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Tue Jul 13, 2010 7:07 am
Or run some 14-7 wire used on goosenecks with trailer brakes. I have used it in two off boats and that's the ticket.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Jul 13, 2010 7:04 pm
Or if you dont have a fish tape, get some saran wrap, ball it up to where it will fit down the longitudinal. Attach some fishing line and put the saran wrap inside the longitudinal. Get an air hose and blow it till it gets to the other side.
Works well. Later
Sun Jul 18, 2010 9:03 am
