ibfishin
Joined: Sun Dec 05, 2010 8:20 pm Posts: 1127 Location: Okeechobee, FL
 Question about Uncle J custom boats
Does antone have a pic and performance numbers of an Uncle J 1848(or similar width) w/huntdeck and a 35 GTR?
_________________ 35 GTR pushing an 18' Alumitech Custom
Wed Dec 29, 2010 7:35 pm |
jordy
Joined: Thu Mar 11, 2010 8:25 pm Posts: 1588 Location: South Louisiana
 Re: Question about Uncle J custom boats
viewtopic.php?f=5&t=11495&hilit=JordyHere is a link to my review on my Nunc j 1854. I know I know it's 6" wider but you'll get the general idea. I have the before stage 1 numbers and the after stage 1 numbers also I have the before and after paint pics. You can't go wrong with an 1854 especially If your pushing it with a 35/36 horse power motor.
Wed Dec 29, 2010 8:03 pm |
ibfishin
Nice boat! Your "trim" adjustment is the same way we stop the alum airboats from porpoising, just tighten a cresent wrench on the lip and bend down slightly until problem is resolved. Does the "trim tab" dig in or affect anything when in hard reverse? I like the idea of the "step" in the GT extreme hulls, seems like a good idea for a boat that can go backwards as well as forwards.
Wed Dec 29, 2010 8:29 pm |
dozrya
Joined: Wed Apr 07, 2010 8:05 am Posts: 1228 Location: Houma, LA
I have an 1848 Uncle J boat.
I have been running my GTR on the middle bolt. Thinking about trying it on the bottom bolt to see if there is a difference or not.
_________________ 1754 Xtreme 35 GTR Stage 1
Wed Dec 29, 2010 9:36 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
Dozrya, when we going hunting?
Thu Dec 30, 2010 8:19 am |
dozrya
Whenever I get an invite from you. I'm off Friday, Saturday, Sunday!! Flat lake or the Wax. I'm down for some coots and teal. I know the wind is supposed to be blowing 15-20 Friday. Probably rough in the Wax.
Thu Dec 30, 2010 8:29 am |
UNCLE-J
It's a date !,,
Can you bring some skanks? I would like to shoot there limit along with yours...
Thu Dec 30, 2010 8:31 am |
cmiller73
Joined: Tue Jan 12, 2010 12:42 pm Posts: 2161 Location: Houma,LA
Ryan, hook up with us Sunday. Bring a few boxes of shells. There are more than teal and coots in Flat Lake also. So bring your decoys.
_________________ Copperhead 12Hp SD on 1442 Alweld
Thu Dec 30, 2010 8:38 am |
Skipr
Joined: Fri Sep 11, 2009 6:48 pm Posts: 701 Location: Houma, LA
I wouldn't consider myself as a skank, but an elite member of the "Bum-a-Hunt Club" since I lost my lease. Just throwing that out there.
dozrya
Chad I have no idea where the fuck I would be going in Flat Lake. Would not mind doing that.
Thu Dec 30, 2010 8:39 am |
jordy
I have since cut off the tab on the back and had a welder fab and weld on some wedges to the bottom. It took about 3-4 adjustment runs to get it rite but now I have better reverse performance in the thick stuff, no propulsion, and gained nearly 2 mph's. A lot of ppl on here say tho that the wedges are not the solution for every boat but it worked like voodoo magic on mine.
JordYb.
Thu Dec 30, 2010 8:43 am |
ibfishin
I'm visualizing the wedges. Can you post a pic? It seems as though you needed a "hook" in the boat to keep the front end under control.
Dozyra has the boat I want except with 21" sides, a smaller underdeck gas tank, winch implement points w/power front and rear, minus the gun box. Is the gunbox waterproof?
Thu Dec 30, 2010 9:16 am |
jordy
viewtopic.php?f=4&t=10436&start=0thats the thread i used whenever i had my wedges made. i made them identical but when i ran my boat with em i had to do come modifications. and no my gun box is not 100% waterproof. if it rains no water gets in from the top, but if a lot of water is in the bottom of my boat there are small areas that the water seeps into. the box is not full seal welded on the bottom. you could easily silicone it up to make it water proof i just havent gotten around to it. everything in my gun box doesnt get soaked just a little bit wet if any at all.
Thu Dec 30, 2010 10:14 am |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
jordy,
if you have no "propulsion" you are dead in the water...
Porpoising maybe?
_________________ Sometimes it's best to just keep your fingers quiet...
Thu Dec 30, 2010 4:58 pm |
UNCLE-J
Thu Dec 30, 2010 5:10 pm |
