It is currently Tue Jul 22, 2025 9:27 am
[ 10 posts ] |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
 Steel Flex
I know this topic has come up before., but.......I have a small 12 foot V hull that I could use for some spots. It is a 1960's rivetted hull and I would like to put steel flex on it. Does Steel Flex only come in gallons or is it available in smaller amounts? How much does this stuff cost? Best place to purchas?
Thanks
_________________ Phowler Extreme 1848 with 36PDFPR
Tue Aug 09, 2011 2:41 pm |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
 Re: Steel Flex
_________________ GTB 1860 w/ 2019 GTR40XD-HO
Tue Aug 09, 2011 2:43 pm |
Frog
 Re: Steel Flex
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Tue Aug 09, 2011 2:44 pm |
Frog
 Re: Steel Flex
Tue Aug 09, 2011 2:51 pm |
mudder
 Re: Steel Flex
Tue Aug 09, 2011 3:03 pm |
mudder
 Re: Steel Flex
Tue Aug 09, 2011 3:12 pm |
mudder
 Re: Steel Flex
So I ended up putting Steelflex on yesterday and it turned our really good. My question, although not looking to put on a second coat, I would like to touch up a couple of spots. Can this be done without any issues the next day? I thought I read somewhere that second coats of steelflex should be applied after the first coat is tacky.
Thanks
Sun Sep 04, 2011 8:35 am |
Frog
 Re: Steel Flex
Its best to re-apply when tacky . Sand it real good and clean with acetone. Remember the thicker you put it on the easier it chips off.
Mon Sep 05, 2011 5:54 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: Steel Flex
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Mon Sep 05, 2011 6:26 pm |
Frog
 Re: Steel Flex
I'm with you tenpoint, I'm a Steel flex-GatorGlide guy but the thicker the Steel flex more it chips of for sure. http://www.youtube.com/watch?v=uhIVCeQWiI4 Especially when doing a recoat Steel flex after the first coat cures. If you're going to lay it up heavy I think after grinding the aluminum with 26 grit wheel a light dusting (not a film)of zinc chromate is a good idea.
Tue Sep 06, 2011 3:51 am |
[ 10 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 127 guests |
