It is currently Fri Feb 13, 2026 2:31 pm
[ 7 posts ] |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
 Transom Saver!
Has anyone come up with a good transom saver for a GTR. I know GT has a trailering bracket, but it does nothing for taking the weight of the transom while trailering. Our fine south Louisiana roads will beat the chit out of the transom with all that weight bouncing around. Thanks
| Tue Aug 25, 2009 9:49 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 Re: Transom Saver!
| Wed Aug 26, 2009 12:08 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: Transom Saver!
I use one of the plastic bumpers that Wilson was talking about and I run a strap across the belt housing.I think that Blaze has a piece of channel that he runs from the trailer to the skeg.
Pulling a boat thru NOLA sucks azz!!!!!
| Wed Aug 26, 2009 5:12 am |
DMC
 Re: Transom Saver!
I just had a fiberglass boat built and want to address this before the engine or transom gets damaged. The rubber bumper idea sounds good for absorbing the shock. I have seen the channel set up and wonder how much stress it puts on the lower unit. Good idea though because it supports the engine and stops it from turning. Thanks for the replies!
| Wed Aug 26, 2009 7:54 am |
Tulsa_Woody
Joined: Wed Jan 14, 2009 8:31 am Posts: 428 Location: Tulsa, OK...Cajun by Marriage
 Re: Transom Saver!
I use a strap now instead of all that rope...but that's all i had at the time and it was a 5 hour haul.
Woody
_________________ 17x54 Gator-Tail w/ 35HP GTR Gator-tail/MM exhaust Center Console...it fixes tiller torque viewtopic.php?f=4&t=9330
| Wed Aug 26, 2009 3:03 pm |
Mudhole
Joined: Wed Jan 14, 2009 7:05 am Posts: 716 Location: NW La.
 Re: Transom Saver!
I made one for my PD, aint sure if it would work ona GT but you should be able to do sumthin simular.....
_________________ "Gofer Everette?"
| Sat Aug 29, 2009 6:40 am |
Pintail58
Joined: Fri Feb 06, 2009 8:17 am Posts: 578 Location: Lafayette , La on da outside
 Re: Transom Saver!
Take the one pictured above and turn it sideways. It should fit at the bottom of your belt drive housing. worth a try...
_________________ Shoot 1st ask later 14' leaker w/ 20hplt Shootin time Teal Season 2010 http://xrl.in/64aw #countdown
| Fri Sep 04, 2009 7:39 am |
[ 7 posts ] |
