It is currently Fri Feb 13, 2026 10:55 pm
Reply to topic  [ 13 posts ]
 Adding flotation inside the boat...
Post Adding flotation inside the boat...
I have a 16 foot boat which i seriously modified the inside to make a blind and such....
So I am wondering what I can do to add floatation on the inside in case I ever take on water.
I was gonna get the expanding foam and just fill all the voids and such but I have heard that is a nono cuz it absorbs moisture and will get super heavy over time
Is this true?
Do they make a marine grade expandable foam?
Is there anything else I can do or Use?
Tue Aug 25, 2009 8:58 pm
Post Re: Adding flotation inside the boat...
http://www.jgreer.com/pour_foam_faq.htm
Check out this page for lots of answers from the "experts"
17' CAT 5 with 37 GTR
Wed Aug 26, 2009 8:38 am
Not 100% sure but I believe da 4'x8' sheets of styrofoam dat you use to wrap you house when building is a closed cell foam dat won't get water logged.
Wed Aug 26, 2009 11:06 am
get good insurance and wear a life jacket :mrgreen:
Wed Aug 26, 2009 11:07 am
Don't put floatation in your boat. Foam is the devil. You don't want to ride around with the devil do you?
Put yer face in the myrtles.
Mon Sep 07, 2009 8:22 pm
1754 GT EXTREME 37EFI
Mon Sep 07, 2009 8:31 pm
talk to muddiejeep about the foam he use to have in his old boat. when he pulled that stuff out it was like an extra 100+ lbs taken out of his boat.
Tue Sep 08, 2009 1:30 pm
Tue Sep 08, 2009 3:20 pm
Foam is some really good stuff. It will make your boat float higher out the water. :? :lol:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Tue Sep 08, 2009 4:15 pm
Y'all laugh about flotation but come on up here when it is 15 degrees outside and blowing 25 gusting 35 and you are out on big water / waves...then tell me you don't want flotation in your boat.
Wed Sep 09, 2009 9:14 pm
Owner
Thu Sep 10, 2009 6:37 am
Thu Sep 10, 2009 12:14 pm
I bought closed cell foam from home depot and put it in between the ribs on my floor and then covered with aluminum. Closed cell foam will not absorb water. Only open cell foam will. You can always test the material before you install to make sure it will not absorb water.
Wed Sep 16, 2009 12:02 pm
