It is currently Fri Feb 13, 2026 2:30 pm
Reply to topic  [ 7 posts ]
 Do you have to have a split seat with a GD Lt or can you....
Post Do you have to have a split seat with a GD Lt or can you....
or can you use any jon boat? A guy told me I would have to have the pods/split seat or I couldn't get the prop all the way out of the water. Help me out. Thanks!
1650 Alumaweld w/a 25 Kohler GDLT
Wed Nov 04, 2009 11:34 am
Post Re: Do you have to have a split seat with a GD Lt or can you....
i had a 1544 Wledcraft with a 27 gdlt on it with a full back seat with no problem at all. My prop would come all the way out the water and the handle would rest on the seat.
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Wed Nov 04, 2009 11:42 am
I just wanted to make sure that it wouldn't affect the mobility of the motor.
Wed Nov 04, 2009 12:20 pm
might need a diff handle but it can be done. I had a 20hp GDLT on a 542 war eagle and it worked fine once I put the duck boat handle on it
Fri Nov 06, 2009 11:21 pm
mine works fine with a 23 gdlt on a 1544 jon. I had a very old 9 gdlt on the same boat and i had to modify the handle but if its a newer lt then you should be fine
37 EFI Prodrive pushing a 1748 Tim's Marine Custom Flat
Sat Nov 07, 2009 1:00 pm
I had a 15'44" Alumnacraft and put my 25GDLT on it and it wouldn't even tilt far enough down to start so I had to cut the back seat all the way out and I put a seat base in the floor with a seat on it to operate it. I was going to cut the center out but the motor needed to move more than just in the center. Hope this helps you any.
16x44 GD boat w/25hp GDLT
Tue Nov 10, 2009 10:44 am
Thanks DU, I guess it all depends on the placement of the back seat and the handle on the motor. I've heard it works, and then it doesn't work. Thanks for the input!
Tue Nov 10, 2009 11:48 am
cron
