It is currently Sat Feb 14, 2026 4:31 pm
[ 8 posts ] |
HUNT4DEER
Joined: Sun Jan 03, 2010 10:39 am Posts: 833 Location: DODGIN ROCKS ON THE RIVER OR CARS ON THE INTERSTATE
 wedge ?
saw a little talk about wedge. are yall talkin about blocks on the bottom of the hull or wedgein the motor at the transom ? when my boat is loaded light it porpusises (?) bad , like jumpin out the water bad. i have to put all the gear i can in the front and fill the live well.
| Mon Jan 04, 2010 8:11 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: wedge ?
They are talkin putting wedges on the bottom of the hull at the transom.
| Mon Jan 04, 2010 1:19 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
 Re: wedge ?
tell a little more about your boat and motor that you have. wedges work great in the right application, but they're not for everyone. I have successfully used them myself...
_________________ 24x60 Dual Prodrives
| Mon Jan 04, 2010 6:10 pm |
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
 Re: wedge ?
Here is a picture of my wedges on my Aucoin 18x48 hull.
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
| Mon Jan 04, 2010 7:03 pm |
HUNT4DEER
 Re: wedge ?
14X48 riveted triton with 23 mini lite. .100 ribbed bottom. with 2 ppl it will carry about 2/3rds of the hull out of the water when trimmed right. by my self i cant trim enough to keep the boat in the water
| Tue Jan 05, 2010 7:53 am |
Crews
 Re: wedge ?
get some thick 3x3 aluminum angle, cut 2 3" sections, then trim one side down to something short, like 5/16. kinda depends on how thick the material is. it doesn't have to be much. then you have some wedges, like you see in the pictures above. put them on the outside corners of the botttom of your boat, just in front of the transom. stick them on with some epoxy, smooth down the leading edge, and go run your boat and see if they work for you. test with and without a load. if they work, knock/grind off the epoxy and pay an aluminum welder a couple bucks to weld them on for you.
if they push your bow down too much, make them shorter. if they don't work good enough, try some taller ones.
| Tue Jan 05, 2010 5:03 pm |
Crews
 Re: wedge ?
I'm sure you could figure out by looking, but the way Jp did it above, he made his solid, that way he could grind down till he got the right height.
| Tue Jan 05, 2010 5:06 pm |
JpEater
 Re: wedge ?
| Wed Jan 06, 2010 6:29 pm |
[ 8 posts ] |
