It is currently Thu Jul 17, 2025 7:03 pm
Reply to topic  [ 22 posts ]
 shark eyes install
Post shark eyes install
ordered some shark eye side lights but they came with no instructions. can somebody give me some pointers before i put holes in the side of my rig? i bought the seachoice lights.
thanks
1850 & 36pd
Wed Jun 30, 2010 2:18 pm
Post Re: shark eyes install
What exactly do you need help with? The installation should be pretty straight forward.
Wed Jun 30, 2010 2:27 pm
like what would be the best way to cut the holes. i kinda hate to just start cutting on it blindly. thought someone who has done it might have some useful info or "what not to do" info.
1850 & 36pd
Wed Jun 30, 2010 3:34 pm
I haven't done the sharkeye's but cut plenty of holes in stuff. Is the hole you have to drill round or oval? I know the lights are oval shaped but didn't know whether the cut was or not. If its round, I'd just use a hole saw thats the right size. Most are designed for wood, but just get a cheap one, it will cut two holes through aluminum. If its oval, I'd probably use a dremel with a spiral cutting bit. Maybe an airsaw, but I would imagine the dremel would be easier. Just put the light where you want and trace the recessed part with a marker and have at it.
Wed Jun 30, 2010 4:07 pm
start out wit a hole saw., i think an 1 1/4, that is the size for the bulk of the light where the bulb is. then take a cutoff tool that goes into a drill. or a drimel if u have it. and taper it back.
Wed Jun 30, 2010 4:15 pm
Profile YIM WWW
cool. thanks. cb5331 the hole is oval.
1850 & 36pd
Wed Jun 30, 2010 4:21 pm
cool, kinda figured it was. What justin said was prolly a lil easier than cuttin the whole thing with a dremel. Cut out the main portion with a hole saw, and then use the dremel to open up the sides until the light fits. Good luck.
Wed Jun 30, 2010 4:35 pm
I cut a pattern out of card paper for the oval and screw hole. THen when I got it like I wanted i traced it on the hull and cut it out. Not something you want to fork up on........
18x48 Charles Leonard / 36PD
Wed Jun 30, 2010 7:28 pm
Plasma cutter would be quick.
Wed Jun 30, 2010 8:08 pm
Normally the shark eye lights come with a gasket, use the gasket as a pattern to cut the hole out.
Thu Jul 01, 2010 11:49 am
Cut mine yesterday and used a jig saw. Used the rubber gasket as a template. Not sure what brand they are. Got them off EBAY for like $12.
Uncle J's 1748 Pro Drive 36
Thu Jul 01, 2010 1:59 pm
Thu Jul 01, 2010 2:25 pm
Thu Jul 01, 2010 2:52 pm
Oh lord... He let the cat out of the bag.
You now have the second boat with shark teeth.
Thu Jul 01, 2010 4:50 pm
Thu Jul 01, 2010 4:52 pm
Profile YIM WWW
LED shark eyes ;) on mine
Thu Jul 01, 2010 5:06 pm
db8 has them on his boat too i belive. the LED's that is.
Thu Jul 01, 2010 5:08 pm
Profile YIM WWW
Cut a hole on each end with the hole saw and use a jig saw to connect the 2.
Thu Jul 01, 2010 6:06 pm
Thu Jul 01, 2010 7:21 pm
Profile YIM WWW
WC 1848 Bateau w/ 36 PD FPR
Fri Jul 02, 2010 7:12 am
Fri Jul 02, 2010 9:54 pm
Profile YIM WWW
The hole where the light socket goes is not a tear drop. Its just oblong. Do as I suggested and you cant go wrong. I talk from experiance. I installed quiet a few.
Sat Jul 03, 2010 10:06 am
Users browsing this forum: Google [Bot] and 143 guests
