Transom Extension http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=10383 |
Author: | mnriver [ Mon Jun 21, 2010 10:41 am ] |
Post subject: | Transom Extension |
Am putting pods on my boat but in oreder to get the motor to clear the pods when turning I will have to make my pods smaller for the clearence i need.Has anyone used a transom extension used to get the motor to sit further back on the transom?The rep at beavertail recomonded it. |
Author: | Josh [ Mon Jun 21, 2010 10:44 am ] |
Post subject: | Re: Transom Extension |
a jack plate? |
Author: | mnriver [ Mon Jun 21, 2010 1:33 pm ] |
Well not too sure what a jack plate is? I just need the motor to sit further back off the transom? |
Author: | Josh [ Mon Jun 21, 2010 2:09 pm ] |
jack plate would do it then. manual or hydraulic is up to you |
Author: | WestEndAngler [ Mon Jun 21, 2010 2:19 pm ] |
Never heard of someone putting a jack plate on a MM normally you see them on outboards but I guess the principle of moving the motor back 4" or so could work for your application. No reason to get a hydraulic one unless you do have an outboard with a tunnel hull etc. |
Author: | indybill [ Mon Jun 21, 2010 2:29 pm ] |
I mounted a manual jack plate on a 1648 to run a stock 35MB tall transom and it worked great. It set back like a drop deck and i could tweek the transom hight. Also worked well when I would change over to a tiller outboard. |
Author: | Team Camo [ Mon Jun 21, 2010 8:50 pm ] |
Can't remember which motor ya ended up with, but if it doesn't have pwr trim, ya could get a CMC trim unit. That would offset the motor and give ya pwr trim. ![]() |
Author: | Gigafowl [ Mon Jun 21, 2010 9:19 pm ] |
Hate to be a "kill joy" but I would swap hulls if I wasn't happy and skip the pod thing... But --- the closest real MM thing to a jack plate might be the Excel F4 duck boat with huntdeck... Deadbird8 just bought one and here is a link to that thread... viewtopic.php?f=17&t=8514&p=91474&hilit=excel#p91474 |
Author: | mnriver [ Tue Jun 22, 2010 6:21 am ] |
Sounds like any easy way to go but it would only be taking a inch and a half off of the inside where it goes straight to angle on the pods so might just be as easy to take that little bit off? |
Author: | balloon-knot [ Tue Jun 22, 2010 6:27 am ] |
I am not sure a jack plate could take the abuse????? They are not made to have motors kicking up ect. I would hate to read 2 weeks from now that your jack plate broke and your motor is on the bottom. Just my .02 |
Author: | mnriver [ Tue Jun 22, 2010 9:46 am ] |
Yeah that could be a problem....solved the porblem took inch and half off the pods,won't loose much out of it. |
Author: | Triple Threat [ Fri Jun 25, 2010 3:50 pm ] |
i now have over a 1000 hours on my boat and the jack plates are holding up just fine.... just a lil info |
Author: | dead duk [ Thu Jul 01, 2010 7:23 pm ] |
I think Willtodo has always used a jackplate on his MM. May want to PM him. |
