retired and broke
 Question for you boat experts
There is a small split that has started leaking on my brothers boat.It is split right next to a runner. Maybe the welder got it a little to hot when making the boat. What is the best way to fix this? I know it needs to be welded but what procedure would you boat builders use? It has to be done from underneath.. Would it be best to put another piece and weld around it or just weld the split? Thanks
Sat Jun 26, 2010 1:06 pm |
quackconsumer
 Re: Question for you boat experts
Drill holes at da ends of da crack so da it does not continue to spread and crack in da future, then weld it up. just my 2 cents.
Sat Jun 26, 2010 1:53 pm |
Dukkilr
Joined: Mon Feb 01, 2010 11:41 am Posts: 61 Location: Iowa
Sat Jun 26, 2010 2:48 pm |
Josh
Joined: Fri May 14, 2010 7:35 am Posts: 1110 Location: Longview TX
take it to brother to fix...
_________________ Sometimes it's best to just keep your fingers quiet...
Sat Jun 26, 2010 8:34 pm |
retired and broke
Sun Jun 27, 2010 9:44 am |
indybill
Joined: Wed Jan 14, 2009 7:38 pm Posts: 581 Location: HOUSTON
R and B I think Josh thought you ment Brother Boat Co. I don't think he was trying to be a SA.
_________________ My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty When the people fear the government that is tyranny"- Thomas Jefferson
Sun Jun 27, 2010 12:43 pm |
OwenDickeson
R & B,
There is a guy that builds boats in henderson, la that goes by the name of Brother. In your post you said your brothers boat and Josh thought you were talking about a boat that Brother built, and thats why he said take it to Brother.
Sun Jun 27, 2010 3:16 pm |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
Couldnt have been tring to be a S.A... Aint none of them on this site...
I sell land iff'n you need some....
Drill the holes and weld it top and bottom if the hull is thick enough to do it that way... .125 and up.. or a real good welder can do thin'r...
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
Sun Jun 27, 2010 3:39 pm |
Josh
yep... Thought you had a brother breaux hull. My bad.
Sun Jun 27, 2010 5:02 pm |
retired and broke
No problem.
Sun Jun 27, 2010 6:29 pm |
UNCLE-J
If I can see the crack from the top, then call me and set an appoint. If it's a day I am welding, I will put a pass on it for free. Though, holes have to be drilled on eah end.
One other thing.... I have never met a SA on this site..
Uncle J 2812167848
Sun Jun 27, 2010 6:34 pm |
indybill
Not trying to say Josh is not a SA just thought at that time It didn't seem so.
Sun Jun 27, 2010 7:12 pm |
Josh
Sun Jun 27, 2010 9:45 pm |
