It is currently Wed Jul 16, 2025 11:29 pm
Reply to topic  [ 13 posts ]
 easier way?
Post easier way?
has anyone found an easier way to remove hydro turf? im bout to give up.
Mon Jun 28, 2010 9:44 pm
Post Re: easier way?
Mon Jun 28, 2010 9:46 pm
Never tried to remove it, but I have some bad arse chisles/scrapers if you wanna try them. May could try and use a hair drier to heat up and possibly melt some of the adhesive. Why are u removing it Josh?[/quote]
i may take you up on those scrapers. im finally getting around to patching the cracks that i have, and im sure the foam is water logged like a sob. seems like im gettin more and more water commin in.
Mon Jun 28, 2010 9:54 pm
try a hair dryer. heat up the glue then one of those large industrial scrapers from home depot / lowes. there like 30 bucks.
Mon Jun 28, 2010 9:57 pm
Profile YIM WWW
Try using steam maybe? I no they use it to take off alot if other stuff. Also 3m has a product to use to get rid of excess adhesive, might work.
Sold my boat so now im ridin in a cozy pick-up truck to the blind to shoot ducks and a 60' Hatteras to catch fish on
Mon Jun 28, 2010 10:00 pm
Is the glue rubbery or hard? I use a huge sharp filet knife to remove laminate from fukked up countertops when I have to, but the glue is kinda rubbery, just peel the corners up and run the knife under it as you peel upwards.
Put yer face in the myrtles.
Mon Jun 28, 2010 10:03 pm
Gas
Mon Jun 28, 2010 10:05 pm
Mon Jun 28, 2010 10:08 pm
Yeah just filet it off then, a thin sharp blade will work, just like skin on a catfish :mrgreen:
Mon Jun 28, 2010 10:11 pm
I replaced a piece of mine on the bow. Best thing I found was a metal paint a scrapper or putty knife with about a 2' wide blade. Sharpen it up and then in a chisel motion cut the bulk off. All that was left was the glue so I then used my grinder with a multi flap sanding disk to knock that off.
18x48 Charles Leonard / 36PD
Mon Jun 28, 2010 10:15 pm
like i said.. Hair Dryer.. it will heat up the glue to melt it then scrape it off. that is the method we use to take stickers off of box trucks n trailers!
Mon Jun 28, 2010 10:25 pm
Profile YIM WWW
finally got all the hydro turf off this morn. i used a heat gun and it was still a pain. i ended up finding 3 cracks, all were located behind the bench at the first weld on three different braces, they went clear through to the bottom. but i should be up and runnin by fri. as for the foam, there was none in the floor, i thought they all came with it to begin with
again thanks for the tips
Tue Jun 29, 2010 7:57 pm
I think they had foam in the floor, and then did without it, and then went back to it. I know my 07' didn't have it but my 09' does
Wed Jun 30, 2010 7:58 am
Users browsing this forum: Majestic-12 [Bot] and 87 guests
