med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 shark eyes install
ordered some shark eye side lights but they came with no instructions. can somebody give me some pointers before i put holes in the side of my rig? i bought the seachoice lights.
thanks
_________________ 1850 & 36pd
| Wed Jun 30, 2010 2:18 pm |
cb5331
 Re: shark eyes install
What exactly do you need help with? The installation should be pretty straight forward.
| Wed Jun 30, 2010 2:27 pm |
med
like what would be the best way to cut the holes. i kinda hate to just start cutting on it blindly. thought someone who has done it might have some useful info or "what not to do" info.
| Wed Jun 30, 2010 3:34 pm |
cb5331
I haven't done the sharkeye's but cut plenty of holes in stuff. Is the hole you have to drill round or oval? I know the lights are oval shaped but didn't know whether the cut was or not. If its round, I'd just use a hole saw thats the right size. Most are designed for wood, but just get a cheap one, it will cut two holes through aluminum. If its oval, I'd probably use a dremel with a spiral cutting bit. Maybe an airsaw, but I would imagine the dremel would be easier. Just put the light where you want and trace the recessed part with a marker and have at it.
| Wed Jun 30, 2010 4:07 pm |
jus10inla
Joined: Tue Jan 13, 2009 5:55 pm Posts: 1636 Location: Baton Rouge, LA (Central)
start out wit a hole saw., i think an 1 1/4, that is the size for the bulk of the light where the bulb is. then take a cutoff tool that goes into a drill. or a drimel if u have it. and taper it back.
| Wed Jun 30, 2010 4:15 pm |
med
cool. thanks. cb5331 the hole is oval.
| Wed Jun 30, 2010 4:21 pm |
cb5331
cool, kinda figured it was. What justin said was prolly a lil easier than cuttin the whole thing with a dremel. Cut out the main portion with a hole saw, and then use the dremel to open up the sides until the light fits. Good luck.
| Wed Jun 30, 2010 4:35 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
I cut a pattern out of card paper for the oval and screw hole. THen when I got it like I wanted i traced it on the hull and cut it out. Not something you want to fork up on........
_________________ 18x48 Charles Leonard / 36PD
| Wed Jun 30, 2010 7:28 pm |
OwenDickeson
Plasma cutter would be quick.
| Wed Jun 30, 2010 8:08 pm |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
Normally the shark eye lights come with a gasket, use the gasket as a pattern to cut the hole out.
| Thu Jul 01, 2010 11:49 am |
fish8503
Joined: Tue May 25, 2010 11:34 am Posts: 87 Location: Montgomery, AL
Cut mine yesterday and used a jig saw. Used the rubber gasket as a template. Not sure what brand they are. Got them off EBAY for like $12.
_________________ Uncle J's 1748 Pro Drive 36
| Thu Jul 01, 2010 1:59 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
| Thu Jul 01, 2010 2:25 pm |
fish8503
| Thu Jul 01, 2010 2:52 pm |
Mitschke
Oh lord... He let the cat out of the bag.
You now have the second boat with shark teeth.
| Thu Jul 01, 2010 4:50 pm |
jus10inla
| Thu Jul 01, 2010 4:52 pm |
chops3131
Joined: Sun Oct 04, 2009 4:34 pm Posts: 1182 Location: Beaumont TX
LED shark eyes  on mine
| Thu Jul 01, 2010 5:06 pm |
jus10inla
db8 has them on his boat too i belive. the LED's that is.
| Thu Jul 01, 2010 5:08 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
Cut a hole on each end with the hole saw and use a jig saw to connect the 2.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
| Thu Jul 01, 2010 6:06 pm |
jus10inla
| Thu Jul 01, 2010 7:21 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
_________________ WC 1848 Bateau w/ 36 PD FPR
| Fri Jul 02, 2010 7:12 am |
jus10inla
| Fri Jul 02, 2010 9:54 pm |
naj
The hole where the light socket goes is not a tear drop. Its just oblong. Do as I suggested and you cant go wrong. I talk from experiance. I installed quiet a few.
| Sat Jul 03, 2010 10:06 am |
