It is currently Thu Jul 17, 2025 7:55 pm
Reply to topic  [ 23 posts ]
 Hydro turf glue
Post Hydro turf glue
Were do you get hydroturf glue and what kind is the best
1860 center console 36 PD
Duck Down Express
[color=#FFBF00]Team Pro-Drive
Sat Jul 31, 2010 4:16 pm
Post Re: Hydro turf glue
I used dap contact cement from lowes or home depot. Just make sure you let it sit for a while and get real tacky before laying the turf
Sat Jul 31, 2010 4:20 pm
3M Super 90 also available at Home Depot
Crisis defines character
Sat Jul 31, 2010 8:42 pm
What kind of prep work or just paint glue on and put hydro turf down and that's it
Duck Down Express
Sat Jul 31, 2010 9:00 pm
Just clean it real good. Mild soap and water would be fine. Scuff it up a little bit, and glue it down. Keep an eye on it while it dries. I know with the contact cement it expanded quite a bit, and bubbled in a few places. I just cut it in as it stretched, and rubbed out the air pockets.
Sat Jul 31, 2010 9:12 pm
It a new custom boat it just got painted Monday
Duck Down Express
Sat Jul 31, 2010 9:17 pm
you got any pics of that paint job?
1848 Brother Breaux
36 hp Pro Drive FPR
Sun Aug 01, 2010 10:19 am
No not yet
Duck Down Express
Sun Aug 01, 2010 10:30 am
Sun Aug 01, 2010 10:59 am
I'll go with duckhuner 88- Wipe it down with denatured alcohol and use the 3M 90. Worked like a charm.
Sun Aug 01, 2010 2:56 pm
If you use the 3M 90 make sure and spray on both the hydro and the boat. Then let it sit up a few minutes. Get some help because once you put it down it is down, there isn't any moving it around.
I did exactly the way the couple posts above mine did. Hasn't been on long so I can't give you a long term opinion but it has held real well. I did have one small seam I put Gorilla Glue on to sure it up both otherwise it was perfect.
Good luck, I am very happy with it and won't have another boat without it.
Sun Aug 01, 2010 11:07 pm
Not to jack this thread but where did you guys get your hydro turf from? looking to get some my boat came with it on the tops of the boxes and want put it on the front deck
1748 pd boat w/ 36pd hht & fpr
Thu Aug 12, 2010 12:56 am
On my last boat I had used contact cement and the boat stayed in the sun and weather for 2 years and never peeled. I did these steps:
1st cut the tuff where you want it to be.
2nd trace out the area that will be covered.
3rd take some 80 grit sand paper and scuff the marked areas.
4th paint contact cement on the boat and the tuff.
5th drink a beer and wait for it to dry then have a friend help you line up your edges and place down.
This is how I am going to do my next boat because I did not have any problems.
Thu Aug 12, 2010 6:22 am
Thu Aug 12, 2010 7:04 am
Thu Aug 12, 2010 7:20 am
Fri Aug 13, 2010 7:26 am
I purchased mine from Gator Trax, but if you are flexible on the camo you can get it cheaper from Hydroturf directly. I posted some pictures below of what it looked like when I laid it down. I laid the sheets down and used a razor blade to cut the hydro turf directly on the boat. Measuring some of the angles i think would be much more difficult. Also, based on the pictures I guess i used a Locite glue! :o
Sun Aug 15, 2010 6:28 pm
I orderd the kind that has the adysive already on there do i need to put any more glue down or is that enough to make it hold
Wed Aug 18, 2010 12:58 pm
Wed Aug 18, 2010 1:02 pm
X2 on Camo Toad Skinz. You can't beat der price and Richard is a stand up guy to do buisness wit.
Wed Aug 18, 2010 1:21 pm
i tried the 3M stuff and ended up re doing it with gorilla glue. lots easier to put on , move and use. and holding a lot better
17ft uncle J w/35 GTR with a few mods....
Wed Aug 18, 2010 6:28 pm
3M sucks
Contact cement works good
Wed Aug 18, 2010 6:32 pm
x2
I use the 3m stuff for wrapping speaker boxes at work, and over time, it always comes off. I couldn't understand how it could possibly hold up in this environment. Contact cement works great, jus gotta let it get tacky before putting the turf down.
Wed Aug 18, 2010 6:37 pm
Users browsing this forum: No registered users and 156 guests
